Bit conversion
Results 1 to 12 of 12
Thread: Bit conversion
    Sep 2006
    Default Bit conversion
    HI,
    i am geting error in compiling my program. I think its because I am doing a subtracion with a binary number and a decimal number
    C:\PBP>pbp -p16f876a lcd3
    PicBasic Pro Compiler 2.46, (c) 1998, 2005 microEngineering Labs, Inc.
    All Rights Reserved.
    PM Assembler 4.07, Copyright (c) 1995, 2004 microEngineering Labs, Inc.
    Error PBPPIC14.LIB 2048 : [202] Illegal Character 'æ'
    Error PBPPIC14.LIB 2064 : [202] Illegal Character 'æ'
    *** 2 Errors ***
    here is the code:
    if right > left Then 'left and right are from sensor reading
    temp =right-left
    temp= temp/right
    temp= temp * 254
    HPWM 1,255-temp,1000
    HPWM 2,255,1000
    k
    Sep 2006
    my question is how do i convert my binary value to a decimal so i can work with it.
    k
    Jan 2006
    Istanbul
    Hi lerameur,
    In your code piece here, first you are missing ENDIF. For now say it is there, then;
    Your variables are all decimal already.
    Also, say that Right = 5 and Left = 2.
    Then,
    IF Right > Left statement will be executed; then
    Temp = Right - Left
    (Temp = 3)
    Temp = Temp/Right
    (Temp = 3/5)
    (Temp = 0)
    Temp = Temp*254
    (Temp = 0)
    In this case, you will get TEMP as zero, because you will always be dividing a small number by a bigger number.
    Also, if you run your code alone, it will not give you any errors.
    IF Right > Left THEN 'left and right are from sensor reading
        Temp =Right-Left
        Temp= Temp/Right
        Temp= Temp * 254
        HPWM 2,255,1000
    'No errors !!
    Thus, you should check the rest of your code. It seems that you have no problem with your IF statement.
    Sep 2006
    ok but how do i get the 0.6 from 3/5
    maybe (3/5)*254 ?
    i do not want zero
    also,
    I removed these lines and it now compiles:
    I thought I needed them...
    'DEFINE CCP1_REG PORTC ‘ Hpwm 1 pin port, RIGHT
    'DEFINE CCP1_BIT 2 ‘ Hpwm 1 pin bit
    'DEFINE CCP2_REG PORTC ‘ Hpwm 2 pin port, LEFT
    'DEFINE CCP2_BIT 1 ‘ Hpwm 2 pin bit
    'DEFINE HPWM1_TIMER 1
    'DEFINE HPWM2_TIMER 1
    k
    why not 30/5 ?
    OR (or i'm right) 3//5?
    There's a Huge difference between a apostroph ' and the other thing
    Jan 2006
    Istanbul
    Floating point is not supported by PBP lerameur. Thus you can not use parenthesis; still zero.
    There are still ways to go around it though, take mister_e's example.
    Multiplying by 10 could work but
    if the difference is too big then need to multiply by 100.
    and then if the difference is very big, word size variable may be, then multiply by 1000 shall work.
    Ex:
    Right = 240 and Left = 235;
    then Temp=5.
    Now, 5/240 or 50/240 will not work.
    You will need to multiply by 100 and have 500/240.
    Thus you need to multiply temp by 10 or 100 or 1000 based on your values.
    Last Post: - 14th June 2016, 08:55
  2. Doubt with interrupt on change
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 16:22
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 11:31
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
