Any idea's on porting this to PBP?
Results 1 to 21 of 21
    Oct 2006
    Cape Town SA
    Default Youre the best!
    Darrel you are amazing!
    I tried this out yesterday and it exactly what I'm looking for ( I am making a fuel consumption / complex odometer for my ancient Land Rover) and as I can't see close up without glasses, but have perfect long distance vision, a normal LCD display on the dashboard is quite useless and I had been considering large 7 seg display, but this is beautiful! Thanks a million.
    PS: any tips on saving a counter on power-down? I was going to have the PIC running off big electrolytic for long power down delay, and then have one port sensing the instant loss of the (voltage divided) 12v ignition and then quickly write to EEProm, but would it be clever to use a brown out flag or something like that?
    Thanks, but the credit goes to Scott Edwards on that one.
    If you have a PIC with an LVD (LOW VOLTAGE DETECT) pin. You can use it to generate an interrupt when it detects the loss of power.
    Then you can imediately set all pins to input and shut-down any on-chip peripherals to save current.
    You should be able to run long enough to save about 8-10 bytes with just 10uf or so..
    Hello Everyone,
    This is cool. Anyone got an idea how to force this code to display 4 digits all the time? From 0000 to 9999? Scotts code works well. I tried dispVal = 0000 prior to the LCDOUT I,cgRAM statement and that did alright to start counter at zero and eliminate the initial display of a psudorandom 4 digit number at startup, I am sure it is simple, alas so am I .
    Ahhh, I figured out 1 way, Preload with dispVal = 10000. I watched it count up until it overflowed and the zeros remained. Are there better ways ?
    LCDOut DEC4 MyVar
    Just comment out this line ...
    ;            if dispVal < decade then blankIt
    Added: Or better yet, make it ...
    LeadingZeros  VAR BIT
                if (LeadingZeros = 0) AND (dispVal < decade) then blankIt
    Then if you want leading zero's just set the bit.
    Thanks Melanie and Darrel,
    That's 4 dirrerent ways - Great! It seems there is always more than 1 way.
    JS
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Generating Timed Fades in PBP - ideas ?
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 10th August 2008, 00:18
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 03:16
