Any idea's on porting this to PBP?
Results 1 to 21 of 21
    Sep 2006
    Indiana, USA
    Default My fault
    Sorry i didnt explain that the code was originally written for a basic stamp,
    hence the nibble sized variable in question. the code is for displaying large charaters on a 4x20 serial LCD or serial backpack equiped LCD. the code writes custom characters to the LCD, then arranges them to make the large 4 line tall numbers (0-9). all this was spit out serially to the LCD. I changed all the serouts in the origonal code to LCDOUT in proper PBP form, but since PBP doesnt have a nibble sized variable, only bytes and words, the WORD sized variable "pat" can't be broken into 4 NIB's (i.e pat.NIB0) like it will let you in pBasic. it can only do two bytes or 16 bits.. i think that is the reason my version of the code (from my first post) isnt working. all i get is a blank LCD.. it would be nice to use this code to display large numbers because it only takes up about 600 WORDs, i've done a version that displays the 16 compass points (NNW) in large text using the first part of this code to write the custom bit patterns to my LCD's CGRAM, but it takes up 3397 WORDs using BRANCH to a subroutine for each compass point which is spelled out in my second reply, anyway, the original code is at:
    http://www.seetron.com/pdf/lcd_an1.pdf
    and as you can see it is written for pBASIC and meant for serial LCD's, i want to convert it to PBP for a parallel LCD..
    Hey Ryan,
    mister_e's concept is correct, you just need to put it into the LCDOUT statement.
    LCDOUT Nibble1, Nibble2, Nibble3, Nibble4
    or you can just put it all in there in one shot...
    LCDOUT pat.Highbyte>>4, pat.Highbyte&$0F, pat.LowByte>>4, pat.Lowbyte&$0F
    Sep 2006
    Indiana, USA
    Default Hmm..
    Still just a blank LCD, I expected to get at least some garbage on the display. anyone got any other idea's what might be wrong? I added:
    LCDOUT "TEST"
    PAUSE 1000
    LCDOUT $FE, 1
    to the code just before the demo loop part and it display's correctly and then clear screens, so i guess its not totally blank, but it doesn't do much else.
    I also tried hooking the LCD to my BS2p and ran my modified version of the code using LCD out in proper pBasic format and it sorta worked but only displayed the bottom 1/4 of the numbers all shifted up to the top line. like what should be displaying on the 4th line of the LCD was showing on the top line and all the rest was off screen.
    There's few missing details here
    OSC type & speed (4,8,16,20.... or internal)
    LCD DEFINEs
    Config Fuses
    Schematic
    Did you added ?
    DEFINE LCD_LINES 4
    You can also use LCDOUT $fe,1,"Hello"
    Some LCD may need some COMMANDUS and DATAUS fine tuning too.
    Here is a complete modification of Scott Edwards Program for big nums.
    Changes are marked in red, and have been tested.
    ;Initialize your hardware first
    'BIGNUMS.BS2 (Display four 1" digits on 4x20 display)
    ' Connect the serial input of a Backpack-equipped 4x20 display to
    ' BS2 pin P0 and run this program. The program will define a set
    ' of symbols that allow it to display 4-line-tall numerals on the
    ' LCD. To incorporate this capability into your own programs, just
    ' substitute your code for the demo loop. When you want to display
    ' a value (0-9999) in big numerals, write it to dispVal, then
    ' gosub bigLCD.
    I       con 254 ' Instruction prefix.
    ClrLCD  con 1 ' Clear-LCD instruction.
    N96N    con $4054 ' 9600 baud, inverted, no parity.
    cgRAM   con 64 ' Address 0 of CG RAM.
    EEptr   var word ' Pointer into EEPROM.
    pat     var EEptr ' Alias for EEptr.
    dispVal var word ' Value to be displayed as big digits.
    temp    var byte ' Temporary byte variable.
    decade  var word
    nbl     var byte ' Index into number-pattern tables.
    digit   var byte ' Current digit to display
    line    var byte ' LCD line
    LCDOUT I,ClrLCD
    PAUSE 500
    ' ====This section may be omitted with newer (post July 96)
    ' ====4x20 Serial LCD modules. Cut from here...============== >>>
    bitPat0 DATA 0,0,0,1,3,7,15,31 ' Left-right up-ramp shape.
    bitPat1 DATA 0,0,0,16,24,28,30,31 ' Right-left " "
    bitPat2 DATA 31,15,7,3,1,0,0,0 ' Left-right down ramp.
    bitPat3 DATA 31,30,28,24,16,0,0,0 ' Right-left " "
    bitPat4 DATA 0,0,0,0,31,31,31,31 ' Lower block.
    bitPat5 DATA 31,31,31,31,0,0,0,0 ' Upper block.
    bitPat6 DATA 31,31,31,31,31,31,31,31 ' Full block.
    bitPat7 DATA 0,0,0,0,0,0,0,0 ' Full blank
    ' <<<...to here. ===============================================
    ;low 0 ' Make the serial output low
    ;pause 1000 ' Let the LCD wake up.
    ' ====4x20 Serial LCD modules. Cut from here...============= >>>
    ;serout 0,N96N,[I,cgRAM] ' Enter CG RAM.
    LCDOUT I,cgRAM
    for EEptr = 0 to 63 ' Write the bit patterns
        Read EEptr,temp ' to the LCD.
    ;    serout 0,N96N,[temp]
        lcdout temp
    next
    ;serout 0,N96N,[I,ClrLCD] ' Clear the LCD.
    LCDOUT I, ClrLCD
    pause 1
    ' Demo Loop: Show dispVal in Big Numerals, Increment, Loop
    again:
        gosub bigLCD
        dispVal = dispVal + 1
    goto again
    ' Subroutine Displaying Large Numbers
    bigLCD:
        for line = 0 to 3
            decade = 1000
            lookup line,[128,192,148,212],temp
    ;        serout 0,N96N,[I,temp]
            LCDOUT I, temp
            for digit = 3 to 0 step -1
                nbl = dispVal dig digit
                gosub getPattern
                if dispVal = 0 and digit = 0 then skip0
                if dispVal < decade then blankIt
                skip0:
    ;            serout 0,N96N,[pat.nib3,pat.nib2,pat.nib1,pat.nib0]
                goto cont
                blankIt:
    ;            serout 0,N96N,["    "]
                lcdout "    "
                cont:
                if digit = 0 then skip1
    ;            serout 0,N96N,[32]
                LCDOUT 32
                skip1:
                decade = decade/10
            next
        next
    ' Subroutines Defining Big-Character Patterns
    getPattern:
    branch line,[first,second,third,fourth]
    ' 0 1 2 3 4 5 6 7 8 9
    first:
    lookup2 nbl,[$0551,$7067,$0551,$0551,$6776,$6555,$0557,$2556,$0551,$0551],pat
    second:
    lookup2 nbl,[$6776,$7767,$7743,$7743,$6776,$2441,$6041,$7703,$2443,$6776],pat
    third:
    lookup2 nbl,[$6776,$7767,$0577,$7751,$2556,$7776,$6776,$7767,$0551,$2536],pat
    fourth:
    lookup2 nbl,[$2443,$7464,$6444,$2443,$7776,$2443,$2443,$7767,$2443,$7443],pat
    Not too hard eh.
    Sep 2006
    Indiana, USA
    Talking Ah!
    Ok, the step -1 was doing it, i tried LOOKUP2 as a last resort before my last post, but still didnt help. thanks, Darrel! works fine now. i probably would have never got that in a million years. Thanks again!
    Honestly..., I had to use the MCSP debugger to find the step -1. Saw that the FOR loop was never getting executed. Made it easy.
    But a million years, you'd have got it.
    Glad to help.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Generating Timed Fades in PBP - ideas ?
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 10th August 2008, 00:18
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 03:16
