PIC10F202 Variable trouble
Results 1 to 23 of 23
    New Zealand
    One thing that strikes me as odd is that when you look at the hex file im my programmer it's in groups of 3 instead of groups of 4 - any clues why?
    This programming error message seems to be popular now. Do a search within the forum or the website of your device programmer AND/OR software.
    Compile and program fine here.
    <img src='http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1111&stc=1&d=116044343 1">
    Jan 2006
    Istanbul
    As mister_e mentioned, it is a popular error. You seem to be having a low voltage issue on your programmer.
    If you can, try a simple code on 12F508.
    If you get the same error then you definitely have a low voltage issue.
    I haven't tested this, but I think this should work if your code is not going to
    grow or use other PBP commands.
    Try this.
    Comment out RR1, RM1, and FLAGS in your PBPPIC12.RAM file and save it.
    R0      VAR     WORD BANK0 SYSTEM       ' System Register
    R1      VAR     WORD BANK0 SYSTEM       ' System Register
    R2      VAR     WORD BANK0 SYSTEM       ' System Register
    R3      VAR     WORD BANK0 SYSTEM       ' System Register
    R4      VAR     BYTE $0F SYSTEM		' System Register
    ;RR1     VAR     BYTE BANK0 SYSTEM       ' Pin 1 Register
    ;RM1     VAR     BYTE BANK0 SYSTEM       ' Pin 1 Mask
    GOP     VAR     BYTE BANK0 SYSTEM       ' Gen Op Parameter
    ;FLAGS   VAR     BYTE BANK0 SYSTEM       ' Static flags
    OPTION_REG VAR  BYTE BANK0 SYSTEM       ' OPTION_REG shadow register
    SOFT_STACK VAR	BYTE[4] SYSTEM		' Software return stack
    SOFT_STACK_PTR VAR BYTE BANK0 SYSTEM	' Sotware stack pointer
    PBP will allocate RAM space by default. Even if it's never used.
    Now simplify this equation by breaking it down;
    Change: IF time2 >= 2 AND b0 = 2 Then dim = dim + 1
    to;
    IF time2 >= 2 Then
           IF b0 = 2 Then
              dim = dim + 1 'if over 20 min then start dimming dim period 4 cycles = 10 mins
    It's the same logic, but PBP doesn't create temp variables just to figure it out.
    Try compiling your code for a 12F629 without making this change, and take a
    peek at how temp variables get created in the .LST file.
    Now make the change, and re-compile it for the 12F629. Temp variables are
    gone. Works the same on pretty much any target I suspect. Just simplify your
    equations by breaking them down into smaller parts. Especially for little parts
    like the 10F.
    Don't forget you have those line items commented out in your .RAM file. As
    your program grows, you compile for another device, use more PBP commands
    etc, one or more might be needed by a library function. You should get an
    error if you have one commented out that's needed.
    It should compile & work leaving you with a whopping whole byte of free
    RAM...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sure it's another approach wich also works and it's free-up 3 Bytes of RAM.
    SOFT_STACK -> 4 BYTE
    SOFT_STACK_PTR -> 1 Byte
    The advantage to use of the EXT modifier avoid to comment-out those .Lib file. Also nice for short-term memory like mine as i should forgot to remove the comment in the right .LIB file
    Quote Originally Posted by bruce
    IF time2 >= 2 Then
    IF b0 = 2 Then
    Yup sounds familiar to my example
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Another option that does not involve ASM, EXT, or altering files (but should work even though it is slightly contrived.)... You are low on Data Ram but big on Program Space (200 of 512 words used) right?
    1) Change the IF-AND-THEN to nested IF-THENs as noted by Steve and Bruce
    2) b0 ranges from 0-3 (2 bits). Drop the b0 variable and stash the values in OPTION_REG<1:0> (with the prescaler pointed to the Timer, which you are not using)
    3)Time2 ranges from 0-73 (7 bits). Drop the Time2 variable and store the lower 5 bits in the FSR register, the 6th bit in OPTION_REG<2>, and the 7th bit in OPTION_REG<4>.
    The rest of your variables fit – the code to deal with the above changes adds some complexity but would not be hard to implement.
    Yet another option (you said commercial product – the price difference between the 202 and the 629 in quantity is about 0.30USD). Live with the loss or charge your customer a little more and have a clean solution with the 12F629.
    Yet another option – take a week to learn ASM if you do not already know it. This part (10F202) has little complexity and it would not be difficult to convert your code to ASM. Bruce has a good ASM example posted in the example code section plus there are lots of good tutorials out there.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Lightbulb
    Depending on the volume of sales you expect, it may be worth the expense of switching to a different compiler for this project.
    I’ve heard that the Hitech PIC C-compiler is very good at producing lean and reliable code. It’s pricey though.
    Another option is the Proton compiler (at least the latest version that comes with PDS). A guy on that forum was able to compile your program using only 12 vars. This is a much cheaper option and should be really easy to port over from PBP (both are basic compilers).
    Alternatively, maybe someone on the PDS forum could simply give you the HEX file for your program (for free or maybe only a small fee).
    It’s a pretty simple program so, unless you’re planning on making lots of changes to it, that may be the cheapest option.
    Cheers,
    ---> picnaut
    Sep 2003
    Vermont
    Question
    Quote Originally Posted by paul borgmeier
    Off/on topic... Can I use PBP to compile for the 202, but other than declaring constants and variables, do everything in assembly? And...will this add code to the program as opposed to writing it on MPASM?
    Ron
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. problem with variable on PIC10f202
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 26th October 2009, 17:29
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Trouble with Serin2 and variable size
    By Ryan7777 in forum Serial
    Last Post: - 5th October 2006, 16:40
