PIC10F202 Variable trouble
Results 1 to 23 of 23
    Jan 2006
    Istanbul
    Hi George,
    If it is not a secret government project, can you post your code?
    New Zealand
    Sure, all it does is dims a light down after 20 minutes of being on.
    @ device pic10F202, mclr_off, protect_off, wdt_off
    TRISIO = %1100
    triac VAR GPIO.2
    trigger VAR GPIO.3
    dim VAR WORD
    Time VAR WORD
    Time2 VAR BYTE
    b0 VAR BYTE
    Clear
    GPIO = 0
    dim = 100
    Start:
    time = time + 1 'increment timer in 1/50 seconds
    IF time > 30000 Then 'make a 10 min increment
    time = 0
    time2 = time2 + 1
    EndIF
    b0 = b0 + 1 'increment for every 4 phase cycles
    IF b0 >= 3 Then b0 = 0
    IF time2 >= 2 AND b0 = 2 Then dim = dim + 1 'if over 20 min then start dimming dim period 4 cycles = 10 mins
    IF dim > 7500 Then dim = 7500 'down to dim level - 9000 = off, 7500 approx 15%
    if time2 > 72 then 'turn off after 12 hours
    dim = 9000
    time2 = 73 'prevent from cycling
    LowSide: 'look for trigger points and trigger triac
    IF trigger = 1 Then lowside 'wait for phase to go low
    GPIO.5 = 0 'weight input to sense zero crossing
    PauseUs dim 'wait for dim period
    Output triac 'fire triac
    triac = 0
    PauseUs 400
    Input triac
    HighSide:
    IF trigger = 0 Then HighSide
    GPIO.5 = 1
    PauseUs dim
    Output triac
    triac = 0
    PauseUs 400
    Input triac
    GoTo start
    It's the down side of those nifty 10Fs with most compiler. The use of assembler is handy in this case... but i'll have a look at this one to see what i can do...
    Not tested but assuming you're not using any Gosubs... it could work.
    Inspiration taken bellow
    http://www.picbasic.co.uk/forum/show...light=modifier
    Sure it could be dangerous.... compile O.K
    TRISIO = %1100
    asm
    dim=SOFT_STACK
    Time=SOFT_STACK + 2
    Time2=SOFT_STACK_PTR
    endasm
    dim   VAR WORD ext
    Time  VAR WORD ext
    Time2 VAR BYTE ext
    b0    VAR BYTE
    Clear
    GPIO = 0
    dim = 100
    Start:
            time = 0
            time2 = time2 + 1
            EndIF
        IF (time2 >= 2) then
           if b0 = 2 Then dim = dim + 1 'if over 20 min then start dimming dim period 4 cycles = 10 mins
            dim = 9000
    LowSide: 'look for GPIO.3 points and GPIO.3 GPIO.2
        IF GPIO.3 = 1 Then lowside 'wait for phase to go low
        TRISIO.2=0 'fire GPIO.2
        GPIO.2 = 0
        PauseUs 400
        TRISIO.2=1
    HighSide:
        IF GPIO.3 = 0 Then HighSide
        GPIO.5 = 1
        PauseUs dim
        TRISIO.2=0
        GPIO.2 = 0
        PauseUs 400
        TRISIO.2=1
        GoTo start
    Good luck!
    New Zealand
    Hey steve - that looks like some funky stuff yr doing there - tho it's still saying that it's unable to fit variable b0. Any easy way to solve it? Else I'm gonna move to a 12F - seems such a waste tho as I'm only using 2 I/Os. I'm trying to design it for a production run - so I did like the cost and form of the 10F.
    be sure you copy past the whole thing above. It compile ok to me. I did few minors change to the one you posted before.
    I guess about a IF (condition a) AND (condition b) then... line... right?
    New Zealand
    Unhappy
    Hey - copied it all across and it compiled thanks - however - it won't program :s
    "ROM programming error at address 0x0000
    Good 0x0025
    Bad 0x0FE7"
    Any ideas on what that could mean?
    Brendon
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. problem with variable on PIC10f202
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 26th October 2009, 17:29
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Trouble with Serin2 and variable size
    By Ryan7777 in forum Serial
    Last Post: - 5th October 2006, 16:40
