day/night sensor
Results 1 to 11 of 11
    Jan 2006
    Istanbul
    I can say that the POT command with LDR type of fast changing resistive devices is not quite precise.
    Do you have any chance of using a PIC with ADC ?
    Or have you tried your circuit with a PIC with ADC?
    Also, POT command with 5K gives the best result as what I have experienced so far. Any value above 5K has not been working well for me (only with POT command though - even 10K was not good).
    Also, why are you using a scale of 100? What was the reason?
    Dec 2005
    The PNA4603H (available from Digikey) outputs a voltage that is proportional to the light level. Its sensitivity and wavelength are similar to that of the human eye.
    Use it on an ADC pin or use it on one input to the comparator and use a potentiometer on the other input to the comparator.
    If you supply it with +5V using a PIC pin and use ADC, you can turn it off between readings to minimize battery drain.
    Aug 2005
    down south
    thank you both
    In my short time "playing" with the PIC I have not tried any of the adc stuff
    the 16f676 is the sister chip to the 630 about the same but with adc
    is this the way I need to go?
    the 100 scale well I worked for 6 hr. before I got some thing that would work
    (on the other project) started with 255 but did not have any luck ajusted both # and until 100 and it worked.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Replies: 6
    Last Post: - 18th January 2008, 09:17
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
