day/night sensor
Results 1 to 11 of 11
    Aug 2005
    down south
    dhouston I did a search for panisonic could not find much.
    sayzer here is a schematic
    Sorry I'm a not a pro on this just a hobbist.
    I guess in a nut shell what I need is a simple,cheap light sensor that has a wide range on the cal. pot, and is easy on the battery.
    Dec 2005
    Quote Originally Posted by grounded
    What do you need besides the PNA4603H data sheet which the first few hundred Google responses point to?
    Aug 2005
    down south
    the smarts to understand them
    sorry dhouston not trying to be a smart (*&(& . but I'm just a hobbist
    I did look at the data sheet but that all greece to me. I'm not even shure what it or does
    i need examples, people telling how they work ,why they work what they are.
    schematics
    sorry
    Jan 2006
    Istanbul
    grounded,
    Are you sure your LDR is 10K-33K ? did you measure it under complete dark and full light with an ohmmeter?
    Aug 2005
    down south
    sayzer its was a 16-33k digi-key pvd-p8103-nd this was from a project that I did last year with a 12f629. the PBP manuel says to use a 5-50k &.1cap this had the greatest span and along with a 5k cal pot was still under the 50k as per the manuel. it worked but the pot had little effect. I just added this to the schematic I posted. which is the new project. this is the code I used with the 12f629.
    Pot GPIO.4,100,DN
    IF DN<140 Then
    GoTo CHECKPIR
    Else
    GoTo MOVIE
    EndIF
    but If I can get a a greater span from the pot this project can be used for multiple things
    thanks
    Jan 2006
    Istanbul
    I can say that the POT command with LDR type of fast changing resistive devices is not quite precise.
    Do you have any chance of using a PIC with ADC ?
    Or have you tried your circuit with a PIC with ADC?
    Also, POT command with 5K gives the best result as what I have experienced so far. Any value above 5K has not been working well for me (only with POT command though - even 10K was not good).
    Also, why are you using a scale of 100? What was the reason?
    Dec 2005
    The PNA4603H (available from Digikey) outputs a voltage that is proportional to the light level. Its sensitivity and wavelength are similar to that of the human eye.
    Use it on an ADC pin or use it on one input to the comparator and use a potentiometer on the other input to the comparator.
    If you supply it with +5V using a PIC pin and use ADC, you can turn it off between readings to minimize battery drain.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Replies: 6
    Last Post: - 18th January 2008, 09:17
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
