SORRY for cross-posting, but I'm new here and I'd better post here instead of the PBP forum.
Hello,
I'm building a new board in order to measure water pressure using some sensors which would provide a variable resistance depending on the level of pressure of water in a pipe.
Electrically they're not so different from a potentiometer, the problem is that the R value is so low (range from 86 to 330 Ohm) that the classic RCtime schema cannot be applied.
I need at least 8 bit resolution from low to high range.
Could you please suggest me the best schema to connect such sensors to a 16F877A?
Leonzio, from Italy
