Darrel,
I have sent you 2 versions of the code. The e-mail explains the prob.
Nikhil
Darrel,
Nikhil
Big Tables ???
No pwôblem, missiou !!! Use an excel sheet creating a text file ( Retlw xx ...) and some asm ( RETLW ...) lines.
Here are ( simple !!! ) examples
Since the RETLW method stores 1 byte per instruction which takes 2 bytes.
A table of 1024 words would use 4096 bytes, instead of the 2048 bytes used by the method shown here ...
Using EXT with Labels
http://www.picbasic.co.uk/forum/show...php?t=3891#LAB
If you are using a 16F as the .zip example shows, then RETLW would be better because it can only store 14-bit words, but not for an 18F.
Hi,Darrel
I think we also must consider the table loading work ... ( humour !!! )
Hey Darrel,
That table approach works well. now im trying to implement a PID controller to maintain the temperature at a desired temp by switching heaters on/off. I am thinking of using the PWM to do this. But I have to calculate my gain,I and D first. I think this can be done using the step response, but do you know what approximate values i can start out with and how to control the PWM with the output drive?
Hey Darrel,
Hi, Nverma
Have a look to : http://www.parallax.com/dl/docs/prod...eb-PC-v1.0.pdf
there's a PID heather project with ALL the coeff. adjustment procedure ...
AND PBP Basic compatible written overall ...
PS ... page 245 ...
Thanks Alain,
I have that same document and have been reading through it. Its quite helpful. I will continue working on this and let u know if I have any further questions.
Nikhil
