Need help with lookup table or direct calculation
Results 1 to 25 of 25
    Oct 2006
    Well I got a 125KB, I think I should be fine!
    Nikhil
    The chip might have 128k, but keep in mind that PicBasic Pro can only address the first 64K of it directly.
    Since the table will only use 2K, you should be fine for now.
    If the program gets "A LOT" bigger, it's possible to place the table in the upper 64k area, but the readcode would need to be changed to ASM.
    But you can worry about that later.
    Jul 2005
    Ahhh... the LOOKUP and LOOKUP2 statements impliment the RETLW method for you. Lots cleaner.
    Several problems: LOOKUP2 will return words, but has a limit of 85 values (and wastes 50% more room then LOOKUP). LOOKUP1 will fit 255 values, but they are only a byte each (but 1 byte takes 1 program location).
    255 is usefull, but 256 would be lots nicer. Using 255 locations just need a work-around for the 256th value, simple in a SELECT-CASE form.
    SO... not the worst, each value gets looked up for it's exact value. You would expect 1024 word lookups to fit in 2K of program memory.
    Ready for it?
    BUT !!!
    The LOOKUP statement needs to start on a even 256 address boundary (don't ask why, it's an assembler issue). To do this, PBP seems to just waste code space till it gets to the next boundary.
    I tried a sample program compiled for a PIC16F88, which has a 4K word codespace. The program did not fit. I looked at the disassembly I saw the problem was with this wasted codespace.
    Since you have 125K it will fit, and hopefully you can accept the wasted space (basically, you'll need 2:1 to fit the lookups).
    Sample code:
        D2A_Result      var word    ' raw data from D2A conversion
        D2A_Conversion  var word    ' converted result
        ' read the D2A, place Result in D2A_result
        select case  D2A_result
            case is <256
                lookup D2A_result.byte0,                     _
                    [$00, $00, $00, $00, $00, $00, $00, $00, _  ' 0-7 lo bytes
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 8-15 lo bytes
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 16
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 24
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 32
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 40
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 48
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 56
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 64
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 72
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 80
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 88
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 96
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 104
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 112
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 120
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 128
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 136
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 144
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 152
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 160
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 168
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 176
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 184
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 192
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 200
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 208
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 216
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 224
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 232
                     $00, $00, $00, $00, $00, $00, $00, $00, _  ' 240
                     $00, $00, $00, $00, $00, $00, $00],     _  ' 248 - 255
                    D2A_Conversion.byte0
                    [$00, $00, $00, $00, $00, $00, $00, $00, _  ' 0-7 hi bytes
                    D2A_Conversion.byte1
            case 256
                D2A_Conversion.byte0 = $00
                D2A_Conversion.byte1 = $00
            case is < 512
                ' same as before, 2 LOOKUP tables
            case 512
            case is < 768
            case 768
            case else
                ' this case handles 769 to 1023
        end select
    If you do run out of codespace, let me know and I'll help with some asm code for this.
    Uhhh, "Much Cleaner"??
    You're kidding right??
    I have to wonder if you've actually read my previous posts.
    Oct 2006
    Hey Darrel,
    Well I have a huge table with all my values. Great!....but i'm noticing that for some values I store in my table, the program deosn't work. Its really weird....do you think that there might be some memory addressing problems/overwriting program code with the Datatable approach?
    Well, I wouldn't think so, but can't really say for sure.
    Can you post it, or send it to darrel at pbpgroup.com. I'm sure I can get to the bottom of it.
    Oct 2006
    Darrel,
    I have sent you 2 versions of the code. The e-mail explains the prob.
    Nikhil
    Wink other solution ...
    Big Tables ???
    No pwôblem, missiou !!! Use an excel sheet creating a text file ( Retlw xx ...) and some asm ( RETLW ...) lines.
    Here are ( simple !!! ) examples
  1. Lookup table syntax.....
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 19th May 2009, 04:45
  2. Lookup table or Math?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2008, 17:55
  3. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 10:38
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 17:56
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
