Need help with lookup table or direct calculation
Results 1 to 25 of 25
    Oct 2006
    Thanks Darrel,
    I'm not exactly sure what the DW command does. And if you look at the example of the EXT with label, could I write code as:
    POT_VALUE CON EXT
    POT_VALUE
    DW (basically enter my precalculated values in order from the one correposidng to 0 all the way to 1023 here)
    And then reading:
    READCODE(POT_VALUE + (OFFSET<<1)),Temperature
    DW is "Declare Data of One Word" in assembly language.
    And, sounds like you've got the right idea for the rest of it.
    Jul 2005
    That's a rather involved calculation to be sure. Honestly, I gave up trying to follow it.
    You have just 1024 input values, I assume these lead to 1024 discrete output values else you wouldn't be looking for a look-up table solution.
    However, can you solve this by some other simpler method? Piecewize linear, interpolation polynomial, or such? Do you have say an excel spreadsheet with the results calculated?
    Also, you don't need EEPROM to save values, you can use RETLW (Return with literal in W) to get a byte look up table, that will take 2048 memory locations to get 1024 words (and yeah, its assembler, but not much).
    Hangover, Germany
    What type of thermometer do you use ?
    I always make a table of maybe 30 points and make an interpolation between this points. It is good for me, but I don't know, what you need...
    Oct 2006
    Ernie,
    Yes I do have an excel spreadsheet with the values calculated. And I could possibly linearize the curve but loose accuracy. But about this RETLW command, how does it work and where can I find the syntax etc etc for it?
    Oct 2006
    Darrel,
    I don't think I can use that approach since the ADCIN command only lets you store the result in a VAR not a CON. How would I tell it what values from 0-1023 to pull out from memory?
    The reading from the POT should be put in a variable.
    The CON is the address of the Data Table that gets stored in program memory.
    Then the A/D reading would be used as an offset into the data table in order to find the correct value.
    Oct 2006
    Thanks Darrel,
    I works GREAT! I just hope now there isn't a limit to the number of values I can put in the Datatable. If there is, then i'm praying that its 1024!!!!!
  1. Lookup table syntax.....
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 19th May 2009, 05:45
  2. Lookup table or Math?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2008, 18:55
  3. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
