day/night sensor
Results 1 to 11 of 11
    Aug 2005
    down south
    Default day/night sensor
    Whats the option for a day/night sensor to be used as a input for a 16f630.
    using PBP
    this is for a joint hobby project with a out of state friend.
    I'm programming the chip he's building the board
    I have used the "pot" command with a LDR and cap which has most of the calibration in the program. I added a cal. pot but it has little effect. and I would hate have to mail the chip back and forth to get the cal. were we need it.
    I've used a LDR, pot, voltage divider& transistor set up but this project is battery operated and I think it could be hard on battery life.
    just wondering if there is a better option.
    as always thanks
    Dec 2005
    Look at the Panasonic PNA4603H.
    Jan 2006
    Istanbul
    Hi grounded,
    Why don't you post your schematic here?
    Aug 2005
    down south
    dhouston I did a search for panisonic could not find much.
    sayzer here is a schematic
    Sorry I'm a not a pro on this just a hobbist.
    I guess in a nut shell what I need is a simple,cheap light sensor that has a wide range on the cal. pot, and is easy on the battery.
    Dec 2005
    Quote Originally Posted by grounded
    What do you need besides the PNA4603H data sheet which the first few hundred Google responses point to?
    Aug 2005
    down south
    the smarts to understand them
    sorry dhouston not trying to be a smart (*&(& . but I'm just a hobbist
    I did look at the data sheet but that all greece to me. I'm not even shure what it or does
    i need examples, people telling how they work ,why they work what they are.
    schematics
    sorry
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 00:05
  4. Replies: 6
    Last Post: - 18th January 2008, 08:17
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
