EEPROM Question
Results 1 to 8 of 8
Thread: EEPROM Question
    Hangover, Germany
    I think we mix up some things....
    He want to use an external EEPROM ?
    Otherwise, PBP can produce the code for the internal eeproms.
    He had to make the data for an external EEPROM by his own....
    pramarn's Avatar
    pramarn Guest
    Thank You All
    Yes I need to use External EEPROM and hot to make data to External EEPROM?
    Thnk you very much
    Jan 2006
    Istanbul
    Quote Originally Posted by BigWumpus
    ....Otherwise, PBP can produce the code for the internal eeproms.
    If you fill up the internal EEPROM with full of data only during the programming of PIC, happens once, how and why would it produce code for that data?
    You can check this by experimenting.
    It is not a running code. Just constant data burned into EEPROM.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. Eeprom question
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 20th April 2008, 20:21
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
