Thank you Mr sayzer
How to write data to EEPROM it need Hard ware to write data same MCU?
Thank you very much
Thank you Mr sayzer
Thank you very much
Check DATA and EEPROM commands. You will see lots of examples.
"The data is stored in the EEPROM space only once at the time the microcontroller is programmed, not each time the program is run"
Thus, DATA content is not included in your code size.
