OSC Calibration byte in wrong location?
Results 1 to 3 of 3
    Sep 2006
    Default OSC Calibration byte in wrong location?
    PIC12F629 (IK word memory architecture)
    Manual states place calibration byte for oscillator at address 3FFh.
    After compiling the cal byte ends up at 7FFh in the hex file.
    Why? Third line byte value 94h is at addr: 07FFh
    All the addr. references is the file point to the word address so why is the calibration byte different? If I place addr 3FFh in PIC Basic shouldn't it be at 3FFh after compiling and assembling?
    END OF HEX FILE
    :10018000051083120F30A300A03002203028630036
    :02019000C7287E
    :0207FE00943431
    :02400E00D43F9D
    :00000001FF
    It is placing this at 03ff.
    :0207FE00943431
    The address in the .hex file is doubled because this format only supports
    8-bits. To find the real address, divide the value by 2.
    07FE / 2 = 03FF.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2006
    Thanks Bruce - that makes perfect sense!
  1. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 09:01
  2. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 23:39
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 19:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
