Its "02 June 2006" !
Results 1 to 5 of 5
    Yup, or use almost the same method but load your strings in the internal EEPROM. you need 9 bytes*12 months=108.
    May 2006
    Del Rio, TX, USA
    A slight refinement to the previous code. I eliminated the macro and made the starting address a constant. Saves a little space. Again, needs a slight modifaction to unpack the character if using a 16F. (I might get to that example later)
    ;Removed variable declaration
    CntMonthletters var byte
    MonthOut       var byte
    MonthOffset    var byte
    MonthString:
    @ da "January  "
    @ da "February "
    @ da "March    "
    @ da "April    "
    @ da "May      "
    @ da "June     "
    @ da "July     "
    @ da "August   "
    @ da "September"
    @ da "October  "
    @ da "November "
    @ da "December "
    ;Added 2 lines for new constant
    Month_addr CON EXT
    @Month_addr EQU _MonthString
    ;Removed the macro and the macro call
    '  Whatever code for main program
    'Start your printout here after any other code
    Printit:
    SerOut2 SO,16468,["TIME: ",HEX2 hh,":",HEX2 mm,":",HEX2 ss,10,13]
    Pause 500
    SerOut2 SO,16468,[HEX2 day," "]
    'Printout the stored Month Strings
              monthoffset = ((mo & %00001111) + (10 * (mo >> 4)) - 1) * 10
              for CntMonthletters = 0 to 8
                   Readcode (Month_addr + monthoffset + CntMonthletters), monthout
                   IF monthout = " "  THEN GOTO QuitMonthPrint
                   SerOut2 SO,16468, [monthout]
              next CntMonthletters
    QuitMonthPrint:
    SerOut2 SO,16468,[" 20",HEX2 yr,13]
    ;This should have been removed in the original!! -->  End Select
    Pause 1000
    SerOut2 SO,16468,[" momth= ",HEX2 mo,13,12]
