Its "02 June 2006" !
Results 1 to 5 of 5
    May 2006
    Del Rio, TX, USA
    Just a quick comment before I get back to work...
    The code hog is all those SEROUT commands! Your duplicating the Day and Year portion of the commands 12 times!!!! Eliminate this by doing the day before the case select, and the the year afterwards.
    May 2006
    Del Rio, TX, USA
    I don't know what pic you are using, but here is a stab at one technique to help you out. It worked on my 18F series pic just fine.
    But fisrt look at Darrel Taylors technique on how to store and retrieve strings in Code Space. This will help you understand what I did. If you are using a 16F, you will need to read this to modify the code.
    Not saying this is the most efficient method, but it's what I came up with at the end of a long day on the quick.
    Month_addr     var word
    CntMonthletters var byte
    MonthOut       var byte
    MonthOffset    var byte
    MonthString:
    @ da "January  "
    @ da "February "
    @ da "March    "
    @ da "April    "
    @ da "May      "
    @ da "June     "
    @ da "July     "
    @ da "August   "
    @ da "September"
    @ da "October  "
    @ da "November "
    @ da "December "
    '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout       ; Returns the Address of a Label as a Word
        CHK?RP Wout
        movlw low Label
        movwf Wout
        movlw High Label
        movwf Wout + 1
    @         GetAddress _MonthString, _Month_addr        ' Get address of String
    '  Whatever code for main program
    'Start your printout here after any other code
    Printit:
    SerOut2 SO,16468,["TIME: ",HEX2 hh,":",HEX2 mm,":",HEX2 ss,10,13]
    Pause 500
    SerOut2 SO,16468,[HEX2 day," "]
    'Printout the stored Month Strings
              monthoffset = ((mo & %00001111) + (10 * (mo >> 4)) - 1) * 10
              for CntMonthletters = 0 to 8
                   Readcode (Month_addr + monthoffset + CntMonthletters), monthout
                   IF monthout = " "  THEN GOTO QuitMonthPrint
                   SerOut2 SO,16468, [monthout]
              next CntMonthletters
    QuitMonthPrint:
    SerOut2 SO,16468,[" 20",HEX2 yr,13]
    End Select
    Pause 1000
    SerOut2 SO,16468,[" momth= ",HEX2 mo,13,12]
    HTH,
    Yup, or use almost the same method but load your strings in the internal EEPROM. you need 9 bytes*12 months=108.
    May 2006
    Del Rio, TX, USA
    A slight refinement to the previous code. I eliminated the macro and made the starting address a constant. Saves a little space. Again, needs a slight modifaction to unpack the character if using a 16F. (I might get to that example later)
    ;Removed variable declaration
    MonthOut       var byte
    MonthString:
    @ da "January  "
    @ da "February "
    @ da "March    "
    @ da "April    "
    @ da "May      "
    @ da "June     "
    @ da "July     "
    @ da "August   "
    @ da "September"
    @ da "October  "
    @ da "November "
    @ da "December "
    ;Added 2 lines for new constant
    Month_addr CON EXT
    @Month_addr EQU _MonthString
    ;Removed the macro and the macro call
    Printit:
    Pause 500
    QuitMonthPrint:
    ;This should have been removed in the original!! -->  End Select
    Pause 1000
