How to saparate variable to array and GLCD Question
Results 1 to 8 of 8
    Jan 2006
    Istanbul
    For Item 1;
    Take a look at the code under this post.
    http://www.picbasic.co.uk/forum/showthread.php?t=3494
    Easy to figure out an array with ShiftIn.
    pramarn's Avatar
    pramarn Guest
    Thumbs up
    Thank you sayzer
    SHIFTIN DAT,CLK,3,[psxdata[0]\8,psxdata[1]\8,psxdata[2]\8,psxdata[3]\8,psxdata[4]\8,psxdata[5]\8,psxdata[6]\8]
    This syntax can be use other command?
    Jan 2006
    Istanbul
    Could you be more specific pls?
    Like what command?
    pramarn's Avatar
    pramarn Guest
    Command
    ADCIN 0, Readvolts 'Get value.
    Count 3, 1000, W1 ''Get value.
    can use this command?
    ADCIN 0, [psxdata[0]\8,psxdata[1]\8,psxdata[2]\8,psxdata[3]\8,psxdata[4]\8,psxdata[5]\8,psxdata[6]\8]
    Count 3, 1000, [psxdata[0]\8,psxdata[1]\8,psxdata[2]\8,psxdata[3]\8,psxdata[4]\8,psxdata[5]\8,psxdata[6]\8]
    Jan 2006
    Istanbul
    You can not do that.
    But what is it you want to do?
    Why do you need to read ADC 0 and put the result in an array? or Count?
    Give more info about your idea. I am sure there is an easy way to get your idea working.
