Decimal to Degrees mathematics help
Results 1 to 18 of 18
    I think that your maxvalue and minvalue should be the raw value from the adc ie. between 0 and 1023 and not the raw value times 64.
    Otherwise this will not work:
    dummy = (AdcResult - MinValue) * 64
    You get a value between 0 and 1023 from the ADC. Then you subtract 2200 from that which will make it negative and you don't want that.
    Try setting the max and min value to the raw reading from the ADC.
    /Henrik Olsson
    Hi sayzer and henrik thanks for your help
    Well,
    ADCON was wrong so I was getting more than a 10bits ADC result
    so ofcouse my minvalue and maxvalue that i noticed was wrong
    so all mathemacics also resulting in a non res_64 variable
    I'm now getting a value of res_64 but and after dividing it by 64 I have
    a nice 360 deg readout,
    Can anyone help with the bitshifting and additional dividing ? to have a
    .1 deg variable and readout ?
    Jul 2005
    With a 10 bit A2D you have a max reading of 1023 counts, which represents 360 degrees. Therefor, each count is 1023/360=2.84... degrees.
    You don't have .1 degree resolution here, you have 3 degree resolution. That .1 degree is not a true number.
    Jan 2006
    Istanbul
    Hi ErnieM,
    I do not think your formula is ok. Your result is not in "degree" by the way. 2.84 is the step for per degree.
    Lets leave 0.1 degree sensitivity issue to our teacher, Alain!
    I love to learn.
    Jul 2005
    Oops, I inverted it. I should have checked the units.
    Resolution = 360 [degrees] / 1023 [count] = .3519... [degrees/count]
    However, you still don't have .1 degree resolution.
  1. variable + decimal
    Last Post: - 18th August 2009, 15:21
  2. Offset to variable howto ?
    Last Post: - 3rd October 2008, 10:36
  3. Conversion to degrees help
    Last Post: - 5th September 2008, 19:03
  4. Help for decimal conversion
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:20
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 21:02
