Code Problem - Strings/ LCD/ internal EEPROM
Results 1 to 15 of 15
    For the buttons stuff, you may find some tips on the following thread
    http://www.picbasic.co.uk/forum/show...utton+function
    For the strings... no need for that, just place the characters in a array, then send the whole array content to the internal EEPROM at a specific adress.
    Once you know where the data is located... you can access, read, write, modify etc etc.
    Nov 2004
    yep, as you say “part by part” it is easy , but when you need to have to scroll with 2 buttons ever the alphabet and send one by one the user selected character to eeprom , this isn’t as easy as it seems … this is where things get “dirty”.
    As for the rest, for example:
    Write:
    DATA $00,"Switch01",0
    Reading:
    For CounterA = 0 to 16
    Read CounterA,value
    If CounterA=0 then goto Main
    LCDOUT value
    Next CounterA
    Works ok , but as a whole …i´ve not been able and not seen anything working …
    The code for strings by Darrel is absolutely brilliant but it misses one point … all the strings are predefined ….not a single one can be user “ personalized”/edit/create (when pics´s in runtime) …this is where I am searching an answer.
    Anyway thanks a lot Mister_E :-)
    Jan 2006
    Istanbul
    Quote Originally Posted by jorge
    y....
    Write:
    Reading:
    Read CounterA,value
    LCDOUT value
    Next CounterA
    How could that work? it would exit the loop the first time it starts running.
    CounterA=0 and then it exits FOR loop when CounterA=1.
    Any missing condition there? or was it supposed to be like If Value=0 then goto Main ?
    Nov 2004
    you are right but this was only a "coderip" out off context.
    the main problem was the one in the main post.
    rgds,
    Jorge
    Hangover, Germany
    Talking
    What is the problem ?
    String in an array ?
    Username var Byte(size_of_username)
    Writing to LCD ?
    LCDOUT STR Username\size_of_username
    Writing to EEPROM ?
    For I=0 to size_of_username:Write EEProm_Adress+I,Username[I]:Next I
    Nov 2004
    First of all thanks for your valuable hints.
    I will sure try your approach
    Although, i was thinking about Darrel’s approach to strings and a way of manipulate , edit/create them...
    See the Darrels great post:
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    but it lacks user defined messages to be stored in EEPROM...like cruising the alphabet and selecting/creating letter by letter the new text....or something like that.
    Thanks jorge,
    But, as you've already noticed. They are two different things entirely.
    I think you should stick with BigWumpus' idea for getting things in and out of the EEPROM, but the editing of the text is going to be a bit harder.
    And, like Melanie said in the post that mister_e pointed out. It's going to be easier with 3 buttons.
    Sorry, not much help.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem runing my code
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 21:36
  3. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  4. LCD will not start
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
