How to modify a LCD character set?
Results 1 to 11 of 11
    Hi flotul,
    Hope it does what you need.
    The normal character set is stored in ROM on the HD44780, so there's no way to change those. You're limited to just the 8 chars of CGRAM.
    If you really need a whole different charset, then a Graphic LCD (GLCD) is the only way to go. But man those things are expensive. Not to mention it'll suck up a lot of program space in the PIC.
    And, there's still stuff on the forum I've never even seen before. I sit in the "Who's On-Line" page alot and watch the search bot's roaming around. Almost everytime I'll see something that looks interesting that I've never noticed before. Having been here since the very beginning, it's amazing.
    When you're looking for things in the forum, sometimes it's better to use the google "Site" search. Just enter site:picbasic.co.uk and then the keywords.
    site:picbasic.co.uk lcd character
    It also allows 3 letter words, wereas searching for "LCD" with the forums search, won't work.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by Darrel Taylor
    Darrel,
    This info is well worth a sticky post in the FAQ section!
    Probably a good idea. And I think I can do even better than that.
    I'll see what I can come up with.
    Thanks Steve,
  1. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  2. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
