Disable/Enable in Interrupts
Results 1 to 5 of 5
    Feb 2005
    Kolkata-India
    Default Hopefully Yes
    The Enable/Disable are compiler directives which does or does not put the PBP int checking codes into you routine. So this should work. Remember strictly for PBP interrupts. Another way is to turn off the individual interrupt settings only keeping the Global INT turned on i.e., INTCON = $80. If you have other peripheral interrupts then they should be turned off too. (By only clearing the PIE bits perhaps) Mention your PIC and interrupts used.
    Sougata
    Default Disable/Enable in Interrupts
    Thanks for the reply.
    The PIC is 16F877 and interrupts are coming from the UART module.
    My concern is if the disable directive needs to be inserted in every subroutine. Logicaly not as it is directive and covers all the block of commands until it finds the Enable pair.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Continuous Interrupts when using DT_INTS and an INCLUDE file
    Last Post: - 15th January 2010, 21:42
  3. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
