Disable/Enable in Interrupts
Results 1 to 5 of 5
    Apr 2013
    Default Re: Disable/Enable in Interrupts
    This would also work but I think it would cause problems for you. For example;
    if you call sub2 before calling sub1, then interrupts wont be disabled
    if you call sub1 and return to main, then again interrupts wont be enabled until you call sub 2
    So my suggestion is to disable - enable interrupts on each subroutine individually.
    Thanks, although back from the dead!
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Continuous Interrupts when using DT_INTS and an INCLUDE file
    Last Post: - 15th January 2010, 22:42
  3. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
