Hi!
I want to make a hobby pc osciloscope using the 18F4550.
I downloaded the EasyHID, tested and works right (i commented the receive routine because i will only transfer data to the pc).
But its too slow....
I implemented a counter in the vb application, the result is that the pbp application generated with easyusb takes 8 secs. to transfer 1000 packets of 8 bytes each.
The stange thing is that if i use easyhid again, but this time i specify 64 bytes per packet, it takes exactly the same ammount of time to transfer 1000 packets of 64 bytes.
1) Is there some PBP code that shows how to configure and use the full or high speed (not HID)?
2) Does the PicBasic instructions USBIn and USBOut works with full or high speed?
Thanks a lot
Jonathan Orrego
Buenos Aires, Argentina
