how to set RCSTA
Results 1 to 10 of 10
    Oct 2003
    holland
    Thanks, I did it also like that. But it looks like a small buggiein the compiler!
    Regards.
    M
    Hi Mat,
    To set the USART to 9-bit mode, use ...
    DEFINE HSER_BITS 9
    RCSTA will automatically be set to 0D0h
    TXSTA will also be set to 60h
    HTH,
    Talking
    i don't know why but my attention was mostely on 'above A0' than on the real purpose ... i just saw that D0.
    Too bad, there's some missing conditions in the Macro
    I think it would also work with a 0 before the D0h in DEFINE HSER_RCSTA.
    Don't think there's anything missing. Sometimes it helps to look at the Defaults in the PBPPIC14.lib file.
    ;* Default hardware serial port values                          *
        ifndef HSER_BITS
    HSER_BITS = 8			; Default to 8 bits
        ifndef HSER_RCSTA           ; Receive register data
          if (HSER_BITS != 9)
    HSER_RCSTA EQU 90h              ; Receiver enabled
    HSER_RCSTA EQU 0d0h		; Receiver enabled for 9 bits
        ifndef HSER_TXSTA           ; Transmit register data
          if (HSER_BITS != 9)
    HSER_TXSTA EQU 20h              ; Transmitter enabled
    HSER_TXSTA EQU 60h              ; Transmitter enabled for 9 bits
    Yeah right... but why the extra 0 before D0? that's another story
    And since the 9 bit mode is probably not a common/popular use.... Anyways there's always many different solution such as set the register directly
    If anything starts with a Letter, the assembler considers it to be either a Label, Variable name, or Text replacement value.
    For it to know that it's a number, it has to start with a digit between 0-9. This is why Variables and Labels can't start with a number.
    So any HEX numbers with A-F in the first digit must be preceeded by a 0.
    In PBP, HEX numbers start with a $, so it can tell it's a number without the 0.
    Oct 2003
    holland
    Thanks all of you. I think I will take the DEFINE HSER_BITS 9 Than I will not forget after a few month what I did there. And why a 0 before, I dont't know, but if they want that, I will do that.
    Thanks Darrel, now I know. We were here at the same time.
    Thumbs up
    Thanks Darrel, it make sense now.
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  2. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  4. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 05:22
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
