Compiler problems
Results 1 to 14 of 14
    Yup it could be this or
    Quote Originally Posted by Melabs Website
    Why do I get an "out of memory" error when I try to compile?
    Compiling large PicBasic Pro source code files can tax the memory of the PC running the compiler. If an Out of Memory error is issued, an alternate version of PBP can be used. PBPW.EXE has been compiled to make use of all of the memory available to Windows 95, 98, NT and 2000. You must, of course, be running in a DOS shell from one of those Windows environments or within Microchip's MPLAB. To execute the Windows version from the DOS command line, simply substitute PBPW for PBP.
    PBPW options filename
    Feb 2005
    Holmfirth England
    Hi guys,
    There is deffo no virus. Micro code studio is trying to use PBPW.EXE, this is what the error message says. "fatal: out of memory (pbpw.exe)"
    I cant understand why it worked this morning but not now. Nothing has been changed on the computer.
    and rebooting didn't solve the problem?
    I remind to have this problem before on another computer... i can't confirm if it was a windows installation or else..
    i'll try to dig in the forum first.
    Jan 2006
    Istanbul
    Here is the exact same problem.
    http://www.picbasic.co.uk/forum/showthread.php?t=2657
    Just as I guessed; compatibility problem: SOLVED !
    Pls check the post BobEdge.
    Feb 2005
    Holmfirth England
    Smile
    Hi again,
    Thanks for all your help.
    I got it to work but I dont know how exactly. It was not the compatability thing tried win95, and win 2000. no joy. Reboot had no effect, re installing MC Studio had no effect. Also it was not a memory issue, system resource logging proved that.
    I saved the file on the c drive & compiled from there using MPASM, and it worked, but I have problems with MPASM, so I unchecked use MPASM, and it worked.
    So I then saved the bas file on the server, which has a very long file extension tree, with all the same settings as before, and bingo.
    Very confused about what was wrong, but at least it works now.
    Again thanks for your help
    Bob...
    OK, so i remind something about the length of the path but can't confirm the maximum allowed. 60-68 character or something like that
    I usually keep my stuff close to the root... something like c:\pbp_Prog
  1. Problems with U2 programmer C30 compiled code
    By minimii in forum Off Topic
    Last Post: - 5th November 2009, 09:43
  2. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 07:14
  3. Compiler refuses to compile
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 21st June 2008, 19:41
  4. compiler help!!!!
    By MINHLE in forum mel PIC BASIC Pro
    Last Post: - 20th April 2008, 18:52
  5. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 21:45
