18F2550 Compile problem
Results 1 to 5 of 5
    Default 18F2550 Compile problem
    I trie to compile the example program, USBCDC but i get the following error:
    Warning[230]c:\pbp\18f2550.inc 20: __CONFIG has been deprected for PIC18 devices. Use directive CONFIG.
    Can anybody tell me what to do?
    Jan 2006
    Istanbul
    This is not an error, just a warning.
    First of all you need to use MPASM for the 18X series, so switch to that if you haven't allready. Then have a look here:
    Specificly the post from Steve (mister_e) on 29th october -05.
    The latest version of PBP (2.47) hides that warning but I think it's best to get used to the new way Microchip wants it.
    Hope it helps!
    /Henrik Olsson.
    Feb 2003
    Quote Originally Posted by NL2TTL
    Its not an ERROR otherwise it would say "Error".
    Its a WARNING that the syntax you are using to declare the configuration has been superceeded by a "new improved" version.
    At the moment both methods work but in a later version of the assembler your declaration may no longer be supported.
    There are several threads covering the topic.
    http://www.picbasic.co.uk/forum/showthread.php?t=4381
    http://www.picbasic.co.uk/forum/showthread.php?t=3943
    Hope that helps
    Keith
    www.diyha.co.uk
    www.kat5.tv
    After a few modification on the include file the pic is up and running again.
    Thank you all
  1. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  2. Array problem (18F2550)
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2008, 19:47
  3. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    Last Post: - 24th September 2007, 11:48
  4. Problem with A port on 18F2550
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 9th May 2007, 23:59
  5. PIC18F452 Compile Problem
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 21st October 2006, 11:47
