how to set RCSTA
Results 1 to 10 of 10
    Oct 2003
    holland
    Default how to set RCSTA
    I use the pic16F876.
    In my definition I want to set the RCSTA register to D0 hex.
    The compiler does not like this.
    When I write:
    DEFINE HSER_RCSTA 90H
    then it is ok
    If I come to A0H or higher the compiler gives an error.
    The compiler is PBP2.47
    Mat
    EDIT: forget me if you readed the previous post version
    Yeah i got issue here too. so just set all register directly whithout the DEFINEs solve the problem....BUT i didn't check what the A0 value did so, it could be normal
    Oct 2003
    holland
    Thanks, I did it also like that. But it looks like a small buggiein the compiler!
    Regards.
    M
    Hi Mat,
    To set the USART to 9-bit mode, use ...
    DEFINE HSER_BITS 9
    RCSTA will automatically be set to 0D0h
    TXSTA will also be set to 60h
    HTH,
    Talking
    i don't know why but my attention was mostely on 'above A0' than on the real purpose ... i just saw that D0.
    Too bad, there's some missing conditions in the Macro
    I think it would also work with a 0 before the D0h in DEFINE HSER_RCSTA.
    Don't think there's anything missing. Sometimes it helps to look at the Defaults in the PBPPIC14.lib file.
    ;* Default hardware serial port values                          *
        ifndef HSER_BITS
    HSER_BITS = 8			; Default to 8 bits
        ifndef HSER_RCSTA           ; Receive register data
          if (HSER_BITS != 9)
    HSER_RCSTA EQU 90h              ; Receiver enabled
    HSER_RCSTA EQU 0d0h		; Receiver enabled for 9 bits
        ifndef HSER_TXSTA           ; Transmit register data
          if (HSER_BITS != 9)
    HSER_TXSTA EQU 20h              ; Transmitter enabled
    HSER_TXSTA EQU 60h              ; Transmitter enabled for 9 bits
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 16th August 2009, 23:57
  2. Interruptus Frustratus
    Last Post: - 17th April 2009, 20:36
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  4. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 04:22
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
