LCD Display not working - PIC heating...
Results 1 to 33 of 33
Threaded View
    SWITZERLAND (french speaking)
    Default LCD Display not working - PIC heating...
    Hi there,
    I'm using a 16F88 and try to get an 2x16 LCD display working.
    I found some examples on how to connect the display to the PIC but when I switch on the programmer (AN589), the display switches on all 1st lines character's pixels (see attachment); nothing else happens. Worse, the PIC is heating (maybe up to 50°C). The circuit is powered by the programmer.
    I don't think that this has something to do with the PIC since I erased it and the same phenomenon happened again.
    According to the documentation I could find, I connected:
    PIC ports Symbol           LCD pin
    PORTA.0	  DB4	           11
    PORTA.1	  DB5	           12
    PORTA.2	  DB6	           13
    PORTA.3	  DB7	           14
    PORTA.4	  RS	            4
    PORTB.3	  E	            6
    -	  Vss - GND	    1
    -	  Vdd / Vcc +5V	    2
    -	  Vee / Contrast    3
    -	  R/W	            5
    I double checked my wiring (used different colours) and don't see what's wrong. Appart the 10k pull-up on MCLR, there are no other components (display DIRECTLY connected to PIC).
    The code is here:
    'LCDOUT PBP command
    'It assumes the LCD will be used with a 4-bit bus with
    ' data lines DB4 - DB7 connected to PICmicro PORTA.0 - PORTA.3,
    ' Register Select to PORTA.4 and Enable to PORTB.3.
    ' It is also preset to initialize the LCD to a 2 line display.
    OSCCON = %01100000                   'Internal RC set to 4MHZ
    Pause 1000                           'Wait for display to initialise
        lcdout $FE, 1                    'Clear LCD
        lcdout $FE, 2                    'Position cursor at home
        lcdout "Hello World"             'Send "Hello World" to LCD on line 1
        lcdout $FE, $C0                  'Position cursor second line
        lcdout "Second line"             'Send "Second line" to LCD on line 2
        pause 1000                       'Pause 1 second to see it
        goto Main
    What am I doing wrong?
    Roger
  1. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  2. Replies: 2
    Last Post: - 5th November 2009, 18:07
  3. PIC16f690 LCD Not Working
    By hhosteam in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2009, 07:26
  4. Replies: 3
    Last Post: - 27th November 2007, 09:56
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 11:09
