Quote Originally Posted by rwskinner
I've been using ULN2803's on about 200 systems for 3 years now driving 24 volt relays which mine require 80 ma, using only the ULN2803's onboard freewheeling diodes and had absolutley no problems.
But I most likely have been lucky according to what you folks are saying.
The only problem I had was when they drive filliment type lamps, the element burns out, shorts, and causes 24 volts to directly sink via the 2803 and fry it.
We're going to fix that by limiting the current going to the 2803 for protection.
Hi
what is the wattage of the filament lamps you are trying to drive with ULN2003--
the issue is with cold resistance of filament lamp and the surge currewnt that flows before the filament becomes HOT-- the driver device should haVE DOUBLE THE CAPACITY OF THE INRUSH CURRENT II believe.
