Need hardware advice: ULN2003A
Results 1 to 40 of 50
    I've been using ULN2803's on about 200 systems for 3 years now driving 24 volt relays which mine require 80 ma, using only the ULN2803's onboard freewheeling diodes and had absolutley no problems.
    But I most likely have been lucky according to what you folks are saying.
    The only problem I had was when they drive filliment type lamps, the element burns out, shorts, and causes 24 volts to directly sink via the 2803 and fry it.
    We're going to fix that by limiting the current going to the 2803 for protection.
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by rwskinner
    Hi
    what is the wattage of the filament lamps you are trying to drive with ULN2003--
    the issue is with cold resistance of filament lamp and the surge currewnt that flows before the filament becomes HOT-- the driver device should haVE DOUBLE THE CAPACITY OF THE INRUSH CURRENT II believe.
    Sarma
    Quote Originally Posted by mvs_sarma
    Hi
    It's not an overload issue, well, it is, but not caused by normal operation. It's when a lamp burns out and we get unlucky enough that the element rolls around or puddles and causes a direct short. We have done two things to stop this.
    1) Changing all the Lamps with LED replacements
    2) Active current limiting circuit
    When I was researching 2803's "after" the fact, I found that lots of arcade games used them to control light arrays, and they too had many problems with lamps shorting and burning up the 2803. There were some pretty neat ideas on the net on how to avoid it.
    Mar 2006
    Hyderabad (India)
    Hi Rwskinner
    If the failure rate is not high and things are running-- i feel no need to change ULN2003 unless it gives you an advantage-- like cost reduction-- etc,
    perhaps you need not change for technology upgradation - as far as failure is occasional and tolerable without letting reputation down-- please continue
    even the diode matrix inside need be used only when load is inductive like a relay coil.
    Sarma
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 27th May 2009, 23:03
  2. Hardware I2C
    Last Post: - 13th March 2008, 13:24
  3. using hardware ports
    By sebapostigo in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 22:01
  4. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:21
  5. PBP hardware oriented?
    By mpavlica in forum PBP Wish List
    Last Post: - 15th June 2005, 06:18
