Need hardware advice: ULN2003A
Results 1 to 40 of 50
Threaded View
  1. #24
    Italy
    PIN 9 must be connected to V+.
    (See picture below).
    Figure 17 shows 7 lamps on my datasheet. Lamps are resistive loads.
    There is no self-induction when you open a circuit with resistive loads
    so there is no need for the protection diodes. The figure 17 is probably
    a pinball circuit, when you press the button you can verify that all the
    lamps are working.
    Your case is the figure 19 on the datasheet.
    Best regards,
    Luciano
    The Datasheet I have:
    http://focus.ti.com/lit/ds/symlink/uln2003a.pdf
    (See page 11, fig. 19)
    (Click to enlarge the picture)
    (About SMD package)
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 28th May 2009, 00:03
  2. Hardware I2C
    Last Post: - 13th March 2008, 14:24
  3. using hardware ports
    By sebapostigo in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 23:01
  4. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:21
  5. PBP hardware oriented?
    By mpavlica in forum PBP Wish List
    Last Post: - 15th June 2005, 07:18
