Nice explanations Luciano. But I am confused.
You are saying, actually, 500mA is only valid when we use one output at a time. Interesting! because if we make a parallel connection as the data sheet says, then this statement can not be correct.
In a parallel connection, we will be using two outputs at the same time.
In that case, we multiply the current capacity so we get 2x500=1000mA, but according your information, "If you use two outputs simultaneously, then the current of each output is limited to 280 mA". So we get back to where we started.
No change!
Isn't this interesting?
Also, what about the protection diodes? I checked the datasheet but very poor information there.
