Need hardware advice: ULN2003A
Results 1 to 40 of 50
    New Jersey
    Well, it's a long story but I can't fit a 1N4001 diode on the board. However, if I need to, I can fit an SMT SOT-23 diode on the board for this purpose. I have some units in service now and my main reason for asking was to know if I should expect problems later on. Like I said, I can't add a thru-hole diode but I can add an SMT verision. It's 500ma SOT-23.
    Jan 2006
    Istanbul
    If you are not using all of the available arrays, you may want to make a parallel connection of the empty ones; thus providing a higher current both through the transistors and diodes.
    New Jersey
    Default Good idea!
    Actually, I am only using two of the seven available outputs. Are you saying to "gang" together something like 3 inputs and 4 inputs then 3 outputs and 4 outputs? Would this provide better protection if the collapsing field is in question?
    Jan 2006
    Istanbul
    Since the load will be divided by the number of arrays you make in parallel, technically it would.
    Datasheet has no detailed info on the diodes though, but the darlingtons support parallel connection and datasheet confirms this.
    New Jersey
    So, here is what I am thinking. If the field is 77mA and it is ganged together with three outputs, it is esentially like switching a coil current of approximately 26mA and the collapsing field has three different paths to go. This is below the 50mA that Melanie said she has used before. Is my thinking correct?
    Chris
    Jan 2006
    Istanbul
    Post
    Your thinking is "technically" correct of course.
    Practically it "should" be correct. Since Melanie has a practical experience, so I say go for it.
    if you only use 2 driver... why not using SOT transistors/Mosfet instead?
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 27th May 2009, 23:03
  2. Hardware I2C
    Last Post: - 13th March 2008, 13:24
  3. using hardware ports
    By sebapostigo in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 22:01
  4. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:21
  5. PBP hardware oriented?
    By mpavlica in forum PBP Wish List
    Last Post: - 15th June 2005, 06:18
