Negative numbers
Results 1 to 10 of 10
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Default Negative numbers
    I'm trying to set a variable to the negative of another variable by saying:
    remaining = -rows
    Where rows has already been set to 8, but remaining seems to end up being set to 0 instead of -8.
    Jan 2006
    Istanbul
    "...Keep in mind that all of the math and comparisons in PBP are unsigned."
    Will you use that negative number in a math operation or is it just for a representation on LCD or sending via a serial comm. etc?
    Unless it has something to do with a previous version of PBP, can't say.
    But this simple program comes up with 248 (-8). PBP 2.46
     @  __CONFIG    _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    define OSC 20
    clear
    remaining var byte
    rows      var byte
    rows = 8
    remaining = -rows
    stop
    Something you might try is ...
    remaining = 0 - rows
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I'm not using it for any math operations, just to control the start of a for loop.
    for i = remaining toremaining + (rows - 1)
        if i < 0 then
            messageScroll[writePos] = $0
        if i >= 0 and i < messagelength then
            messageScroll[writePos] = message[i]
        if i >= messageLength then
            messageScroll[writepos] = $0
        writePos = writePos + 1
    next i
    for some reason when remaining is negative this part "crashes"
    Jan 2006
    Istanbul
    Hi RUBiksCUbe,
    Where do you get this "Remaining" variable into negative? Are you setting it to "negative" somewhere before this loop as you stated in the example above?
    Also, here I made the same code of yours in a different look.
    It seems you only need the negative value for " messageScroll[writePos] = $0 "
    for i = remaining to remaining + (rows - 1)
        if i < 0 then
            if i < messagelength then
    next i
    Also, are you setting other variables to an initial value at the beginning?
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    At the very beginning I have
    rows = 8
    remaining = (0 - rows)
    Couple problems here.
    As Sayzer pointed out ... "...Keep in mind that all of the math and comparisons in PBP are unsigned."
    This means that
    if i < 0 then
    will always evaluate to FALSE. And the FOR loop will always terminate before executing anything because -8 is really 248 in PBP math (assuming byte vars).
    You'll need to find positive numbers to work with.
    Or testing the MSB of the variable. If 1=> negative if 0=>positive.
    Mar 2006
    INDIA
    I make load indicator with loadcell, i using pic 16f877. For 16 bit adc i using cd4066 , value from -65535 to +65535 with peak hold
    I setup - reading
    B0 var word ( reading of adc )
    B1 var word
    B2 var byte
    main: if B0 > 0 then ( B1 = B0 ) and ( B2 = 43 ) ' 43 is + sign
    if B0 < 0 then B1 = ( 65535 - B0 ) and ( B2 = 45 ) '45 is - sign
    lcdout $fe,1
    lcdout " Load ", B2, dec5 B1
    Jan 2006
    Istanbul
    Quote Originally Posted by precision
    Hi precision,
    Your IF statements are not precise
    You should correct them as follows.
    if B0 > 0 then
     B1 = B0
     B2 = 43
    if B0 < 0 then
     B1 = 65535 - B0
     B2 = 45
    B0 never equals to zero?
    This is actually the idea of assigning a flag that will indicate negative status.
    That is why I asked above, will you use this negative number in a math operation.
    You can have a flag, like NegFlag=1 meaning you have the negative value, and NegFlag=0 meaning positive value.
    If of course it can be useful in your case.
  1. Working with 3 byte numbers
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 23:59
  2. Splitting numbers and recombining them(EEPROM Error)
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2007, 07:40
  3. Returning whole numbers for DS1820?
    Last Post: - 12th February 2007, 13:15
  4. Reading (ADC) negative current
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st November 2006, 18:38
  5. Can PBP understand negative numbers?
    Last Post: - 13th June 2005, 01:23
