Compile "opcode"
Results 1 to 2 of 2
    Jul 2006
    Default Compile "opcode"
    I tried compiling the code below for a PIC16F628A and I got and error stating:
    " opcode expected instead of '__config' ". Please help...
    -Mike
    CODE:
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _MCLRE_ON & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
    TRISB = %11101011
    CMCON = 7
    Baud con 16780 ' 2400 bauds
    Pre CON $A5
    Synch CON "~"
    In var byte
    LOW PORTB.2 ' inverted mode normal idle state
    pause 50
    if (PORTB.1 = 0) then pressed
    Pressed:
    serout2 PORTB.2, baud, [Pre, Synch,"1"]
    serin2 PORTB.3, baud, [WAIT(Synch),in]
    if (in == "1") then
    high PORTB.4
    pause 250
    low PORTB.4
    pause 250
    Jan 2006
    Istanbul
    Change:
    to:
    @ DEVICE INTRC_OSC_NOCLKOUT & MCLR_ON & LVP_OFF & WDT_OFF & PWRT_ON & BOD_ON
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 17:43
  2. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  3. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 09:18
  4. Cannot compile for 40MHz 4 x pll
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 18:50
  5. Replies: 2
    Last Post: - 9th February 2006, 23:03
