PIC16F767 blinking code
Results 1 to 13 of 13
    Jan 2006
    Istanbul
    Quote Originally Posted by danielhr77
    Because OSCCON=%01110000 sets the internal oscillator to 8Mhz...
    For sure it does set it to 8Mhz but don't we also need to state DEFINE?
    I don't think so... So far It's working fine...
    I think that DEFINE OSC is for external oscillators only, but not sure...
    NOPE, DEFINE is a compiler directive and MUST be added at the top of the code. OSCCON is a PIC register that must be set like all the otheres. Let's Say TXSTA, RCSTA, SPBRG.
    Do a simple Test, with your current OSCCON setting do a simple LED blink. use DEFINE OSC 4.. then use DEFINE OSC 8
    what happen?
    Jan 2006
    Istanbul
    Quote Originally Posted by mister_e
    what happen?
    That is what I thought so.
    Daniel, could you pls test it and post the result?
    With DEFINE OSC 8 the LEDs are blinking slowly...
    With DEFINE OSC 4 the LEDs are blinking faster...
    I'm confused... :|
    Normal... they have to blink twice the speed of DEFINE OSC 8 right?
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
