PIC16F767 blinking code
Results 1 to 13 of 13
    Default PIC16F767 blinking code
    Hello Guys,
    I'm having some problems trying to make this pic to work, do you see anything wrong with my blinking code?
    @ DEVICE PIC16F767, INTRC_OSC_NOCLKOUT, WDT_ON, PROTECT_OFF
    OSCCON=%01111000 '8Mhz
    TRISB = 0
    loop:
    High PORTB.7
    Pause 500
    Low PORTB.7
    Pause 500
    GoTo loop
    Anything missing on the @ statement?
    Thank you very much.
    Daniel.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Two ideas to try:
    1) Try OSCCON %01110000 instead of %01111000 (you do not appear to be switching from a Primary OSC - see first few paragraphs of datasheet section 4.6 and description (and foot note) of OSCCON<3>)
    2) What are you doing with MCLR - is it tied high?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Hi Paul,
    Thanks for your help, I've been working with pics for almost four years now, but never used the internal oscillator before.
    I think I'm having some problems with my parallel programmer, because is not programming the code.
    Do you know if the 16F767 need any special requirement to be programmed?
    Daniel.
    At last, after two weeks and a new programmer, a 16F767 working blinking code:
    @ DEVICE PIC16F767, INTRC_OSC_NOCLKOUT ; System Clock Options
    @ DEVICE PIC16F767, WDT_ON ; Watchdog Timer
    @ DEVICE PIC16F767, PWRT_ON ; Power-On Timer
    @ DEVICE PIC16F767, MCLR_OFF ; Master Clear Options (Internal)
    @ DEVICE pic16F767, PROTECT_OFF ; Code Protect Off
    OSCCON=%01110000
    High PORTB.7
    Pause 500
    Low PORTB.7
    Pause 500
    GoTo main
    Jan 2006
    Istanbul
    Hi Daniel,
    Is "DEFINE OSC 8" necessary in this case or not?
    Eventhough you set OSCCON, how does PBP know that it is 8Mhz?
    Because OSCCON=%01110000 sets the internal oscillator to 8Mhz...
    Read the 16F767 datasheet section 4.6.3 for other frequencies...
    PICs makes me love and hate them at the same time....
    In those situation, you need to take a break and have a cup of coffee
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1118&stc=1&d=116054038 5">
    Jan 2006
    Istanbul
    Quote Originally Posted by danielhr77
    For sure it does set it to 8Mhz but don't we also need to state DEFINE?
    I don't think so... So far It's working fine...
    I think that DEFINE OSC is for external oscillators only, but not sure...
    NOPE, DEFINE is a compiler directive and MUST be added at the top of the code. OSCCON is a PIC register that must be set like all the otheres. Let's Say TXSTA, RCSTA, SPBRG.
    Do a simple Test, with your current OSCCON setting do a simple LED blink. use DEFINE OSC 4.. then use DEFINE OSC 8
    what happen?
    Jan 2006
    Istanbul
    Quote Originally Posted by mister_e
    what happen?
    That is what I thought so.
    Daniel, could you pls test it and post the result?
    With DEFINE OSC 8 the LEDs are blinking slowly...
    With DEFINE OSC 4 the LEDs are blinking faster...
    I'm confused... :|
    Normal... they have to blink twice the speed of DEFINE OSC 8 right?
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
