New At PIC's, need some help with code
Results 1 to 20 of 20
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Okay so then here is an updated code:
    '----------Code for the Front Left, Front Right, Back Left, and Back Right
    SYMBOL PORT_PIN = PORTB
    X VAR BYTE ' For loop & bit index pointer
    ADCON1 = 7 ' All digital
    PORTB = 0 ' Clear port pins
    TRISB = 0 ' Make them all outputs
    FOR X = 0 TO 7
    PORT_PIN.0[X] = 1 ' Set all pins high
    PAUSE 200
    NEXT X
    GOTO Off
    Off:
    PORTC = 0
    TRISC = 0
    FOR X = 0 TO 7
    PORT_PIN.0[X] = 0 ' Set all pins low
    PAUSE 200
    NEXT X
    GOTO Main
    '----------Code for Both Sides
    PORTA = 0
    PORTC = 0
    TRISC = 0
    Wait:
    INPUT PORTA.0
    IF PORTA.0 = GOTO Main
    GOTO Wait
    FOR X = 0 TO 15
    PAUSE 200
    NEXT X
    GOTO Off
    Off:
    PORTC = 0
    TRISC = 0
    FOR X = 0 TO 15
    PAUSE 200
    NEXT X
    GOTO Main
    How does that look? For the front and back ones I only need 6 outputs but I need 16 for the sides. I hope I did that INPUT thing right. I assumed that PORT_PIN would still equal PORTB since I'm only using PORTA for the INPUT. Did I do everything correct? Also, I am using a 16F876 so all PORTB and PORTC pins can be outputs, however PORTA.6 and PORTA.7 are unimplemented so that is why I am starting with PORTB.
    Thanks again.
    -Brad
    there's a missing value in that one, 0 or 1
    Also, as you're using PORTB and PORTC, there's no special need to use the array method. Just use
    HIGH x (from 0 to 15)=> refer to section 4.11 of your PBP manual
    something like
        ' Clear portB&C pins
    PORTB = 0
    PORTC = 0
    TRISB = 0
    TRISC = 0
        ' Set PORTA.1 as input
    TRISA.1=1
         FOR X = 0 TO 7
             HIGH X ' Set all pins high
             PAUSE 200
             NEXT X
    Off:
        FOR X = 0 TO 7
            LOW X ' Set all pins low
            PAUSE 200
            NEXT X
        GOTO Main
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Alright here is an updated code as of 10:12 last night
    '---------- FRONT TWO PICS' CODE
    X VAR BYTE
    ADCON1 = 7  'sets all as digital
    PORTB = 0  'clears port pins
    TRISB = 0  'sets as outputs
    Main:                              'turns each LED on
         FOR X = 0 TO 7
              HIGH X
              PAUSE 200
         NEXT X
    PAUSE 7000                     'waits for sequence to finish
    GOTO Off
    Off:                                'turns each LED off
         FOR X = 0 TO 7
              LOW X
              PAUSE 200
         NEXT X
    PAUSE 6000
    GOTO Main
    '---------- SIDE TWO PICS' CODE
    X VAR BYTE
    PORTB = 0  'clears all port pins
    PORTC = 0
    TRISB = 0  'sets all as outputs
    TRISC = 0
    TRISA.0 = 1  'set as input
    Wait:                              'wait for high signal
         INPUT PORTA.0
         IF PORTA.0 = 1 THEN GOTO Main
    GOTO Wait
         FOR X = 0 TO 15
              HIGH X
              PAUSE 200
         NEXT X
    GOTO Wait_Again
    Wait_Again:                   'waits for low signal
         INPUT PORTA.0
         IF PORTA.0 = 0 THEN GOTO Off
    GOTO Wait_Again
         FOR X = 0 to 15
              LOW X
              PAUSE 200
         NEXT X
    GOTO Wait                     'restarts
    '---------- BACK TWO PICS' CODE
    X VAR BYTE
         INPUT PORTA.0
    GOTO Wait
         FOR X = 0 TO 7
              HIGH X
              PAUSE 200
         NEXT X
    GOTO Wait_Again
         INPUT PORTA.0
    GOTO Wait_Again
         FOR X = 0 to 7
              LOW X
              PAUSE 200
         NEXT X
    GOTO Wait                     'restarts
    How does that look? I went and double checked everything so I think it is near completion. Are there any mistakes or better ways to code it?
    First code:
    You don't need the GOTO Off... it will jump there anyway
    Second code:
    Wait and Off are reserved word, so you need to change them
    GOTO Wait_Again    '******* not needed
         INPUT PORTA.0 '***** this one you don't need it as it's
                       ' already defined above
         INPUT PORTA.0 '******* same thing here
    another method
    X VAR BYTE
    PORTC = 0
    TRISC = 0
    Start:
         While PORTA.0=0 : Wend ' wait 'till PORTA.0=1
         FOR X = 0 TO 15
              HIGH X
              PAUSE 200
              NEXT X
         While PORTA.0=1 : Wend 'waits for low signal
         FOR X = 0 to 15
             LOW X
             PAUSE 200
             NEXT X
        goto start
    Jan 2006
    Istanbul
    Quote Originally Posted by mister_e
    Who/what reserves the "wait" Steve?
    I did not know that!
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Okay I updated it again...
    X VAR BYTE
    Turn_On:                        'turns each LED on
         FOR X = 0 TO 7
              HIGH X
              PAUSE 200
         NEXT X
    Turn_Off:                       'turns each LED off
         FOR X = 0 TO 7
              LOW X
              PAUSE 200
         NEXT X
    PAUSE 6000
    GOTO Turn_On
    X VAR BYTE
    PORTC = 0
    TRISC = 0
    Waiting:                              'wait for high signal
         IF PORTA.0 = 1 THEN GOTO Turn_On
    GOTO Waiting
         FOR X = 0 TO 15
              HIGH X
              PAUSE 200
         NEXT X
         IF PORTA.0 = 0 THEN GOTO Turn_Off
    GOTO Wait_Again
         FOR X = 0 to 15
              LOW X
              PAUSE 200
         NEXT X
    GOTO Waiting                     'restarts
    X VAR BYTE
    GOTO Waiting
         FOR X = 0 TO 7
              HIGH X
              PAUSE 200
         NEXT X
    GOTO Wait_Again
    TURN_Off:                              'turns each LED off
         FOR X = 0 to 7
              LOW X
              PAUSE 200
         NEXT X
    I changed the names to unreserved names and I took out my INPUT statements.
    Jan 2006
    Istanbul
    This line will execute AFTER the sequence is finished.
    So you wait 7 seconds additionaly; and while waiting nothing will take place.
    Quote Originally Posted by sayzer
    wait is also a modifier for Hserin, Serin2, etc etc.
    Jan 2006
    Istanbul
    "There's no problem. Only learning opportunities."
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 09:02
  2. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Making Program Code Space your playground...
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 19:51
  5. Writing code for battery operated projects
    Last Post: - 16th June 2005, 03:39
