New At PIC's, need some help with code
Results 1 to 20 of 20
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    BRAD,
    What PIC? You posted in the PBC section and not PBP - is this correct? If you are using PBC, try
    'Example for 16F628A with PBC (Not PBP)
    POKE $86, 0	' all of PORTB output (optional line but good programming practice)
    POKE $06, 0	' all of PORTB low (optional line but good programming practice)
    MAIN:
    PAUSE 500     ' no LED on
    FOR B0 = 0 to 3
         HIGH B0      ' turn ON  RB0, then RB1, then RB2, then RB3
         PAUSE 500 ' pause half a second
    NEXT B0
    FOR B0 = 0 to 3
         LOW B0      ' turn OFF  RB0, then RB1, then RB2, then RB3
    NEXT B0
    GOTO MAIN
    You might also want to check out Melanie's excellent post here
    http://tinyurl.com/gpt6b
    and search the forum for "rider" (as in knight rider) for more visual ideas.
    Any questions?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Thanks for the replies...
    I think I will test out a code I created using some of the elements from the code you guys gave me...
    Hopefully it'll work and I can get this thing going...
    -Brad
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Okay well I will use the code from the link Sayzer gave me...
    I am making an LED Underbody Kit though and so one PIC will control the front left, one will control the left side, one will control the the back left, and the same for the right side. So I will need my PIC's to communicate. When the last LED on the front left is turned on I want the side to start sequencing and same goes for the transition from side to back.
    To do this will I have to set the final output on the front left to go high and then have it connected to an input on the side PIC? That way I could tell the side PIC not to do anything until that input receives a "high" signal from the other PIC. I could do that correct? If so, how would I program it?
    Thanks again for all your help guys.
    -Brad
    Jan 2006
    Istanbul
    If I understood correct, this should be it. Just an example though.
    Wait:
    IF PORTA.1 = 1 THEN GOTO Loop
    'This is the pin you get the input signal from the other PIC.
    GOTO Wait
    Loop:
    'Your loop code should be here....
    'When the last loop index is achieved,
    'you will HIGH a pin to activate the next PIC
    'and you will go back to "Wait"
    GOTO loop
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Here is the code I came up with...
    SYMBOL PORT_PIN = PORTA
    X VAR BYTE ' For loop & bit index pointer
    Wait:
    IF PORTA.1 = 1 THEN GOTO Main 'checks if input recieves high signal
    GOTO Wait
    On:
    ADCON1 = 7 ' All digital
    PORTA = 0 ' Clear all port pins
    PORTB = 0
    PORTC = 0
    TRISA = 0 ' Make them all outputs
    TRISB = 0
    TRISC = 0
    FOR X = 0 TO 23
    PORT_PIN.0[X] = 1 ' Set all porta, portb, and portc pins high
    PAUSE 200
    NEXT X
    GOTO Off
    Off:
    PORTB = 0
    PORTC = 0
    TRISB = 0
    TRISC = 0
    FOR X = 0 TO 23
    PORT_PIN.0[X] = 0 ' Set all porta, portb, and portc pins low
    PAUSE 200
    NEXT X
    GOTO On
    My only question now is, how do I set PORTA.1 to be an input? In my code I set all PORTA pins to be outputs. Is there a way I can set just PORTA.1 to be input?
    As always, I appreciate your help.
    -Brad
    Jan 2006
    Istanbul
    1. You first need to set the TRIS register for a port. Having TRISA = %00000000 makes all pins output. From right to left they are arranged as porta.0 to porta.7. (F877 has 6 pins on PORTA). If you want to make one of them an input, say you need PORTA.1 as input, then you state TRISA = %00000010. Now, all of them are outputs except for PORTA.1 (also for some PICs, you need to watch for MCLR pin which is an input-only pin).
    OR, you can just say INPUT PORTA.1
    2. You should keep all registers at the beginning. No need to put them into each subroutine.
    3. ON is a reserved word. Thus, you can not use it for another purpose.
    4. In your code you have "goto Main" but there is no Main. I think you meant "goto ON", but since you can not use "ON", just change ON to Main.
    5. For the FOR loop you have, you will not have 8-bits on PORTA. Thus you need to have a look at there. Check Bruce's example on the link above.
    Check the datasheet of the PIC you will use. Check which pin can be used as an input-only and/or output-only etc.
    Also, check how many pins you have on each port.
    SOHCKing03's Avatar
    SOHCKing03 Guest
    Okay so then here is an updated code:
    '----------Code for the Front Left, Front Right, Back Left, and Back Right
    SYMBOL PORT_PIN = PORTB
    PORTB = 0 ' Clear port pins
    TRISB = 0 ' Make them all outputs
    FOR X = 0 TO 7
    PORT_PIN.0[X] = 1 ' Set all pins high
    PAUSE 200
    NEXT X
    GOTO Off
    Off:
    PORTC = 0
    TRISC = 0
    FOR X = 0 TO 7
    PORT_PIN.0[X] = 0 ' Set all pins low
    PAUSE 200
    NEXT X
    GOTO Main
    '----------Code for Both Sides
    PORTA = 0
    PORTC = 0
    TRISC = 0
    Wait:
    INPUT PORTA.0
    IF PORTA.0 = GOTO Main
    GOTO Wait
    FOR X = 0 TO 15
    PAUSE 200
    NEXT X
    GOTO Off
    Off:
    PORTC = 0
    TRISC = 0
    FOR X = 0 TO 15
    PAUSE 200
    NEXT X
    GOTO Main
    How does that look? For the front and back ones I only need 6 outputs but I need 16 for the sides. I hope I did that INPUT thing right. I assumed that PORT_PIN would still equal PORTB since I'm only using PORTA for the INPUT. Did I do everything correct? Also, I am using a 16F876 so all PORTB and PORTC pins can be outputs, however PORTA.6 and PORTA.7 are unimplemented so that is why I am starting with PORTB.
    Thanks again.
    -Brad
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 09:02
  2. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Making Program Code Space your playground...
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 19:51
  5. Writing code for battery operated projects
    Last Post: - 16th June 2005, 03:39
