blinking stops
Results 1 to 10 of 10
Thread: blinking stops
    Sep 2006
    Default blinking stops
    hello,
    I just finish building the easyProgrammer. I am now
    doing test. I was able to program a few chip with a
    led blinking program.
    But it blinks for a few seconds only,10
    sec with a 16F648 and the same with a F88.
    i use the program in the picbasic compiler pro on page 6.
    Althought I see that there is setting of the clock anywhere
    ken
    Feb 2003
    Can you post your ENTIRE code so we can see if there are any errors in it.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2006
    oK HERE IT IS:
    loop: High PORTB.0 ' Turn on LED connected to PORTB.0
    Pause 500 ' Delay for .5 seconds
    Low PORTB.0 ' Turn off LED connected to PORTB.0
    Goto loop ' Go back to loop and blink LED forever
    aslo, I tried this code I found on google and it works fine:
    pragma target chip 16f628 -- no 16f818 support yet
    pragma target fuses 0x3F22
    pragma target clock 20_000_000
    pragma target osc hs
    include jpic
    include jlib
    var bit LED is pin_a0
    pin_a0_direction = output
    asm bsf status, 5
    var volatile byte ADCON1 at 0x9F = 0x06 -- disable port a analog functions
    asm bcf status, 5
    forever loop
    LED = low
    delay_10ms( 25 )
    LED = high
    delay_10ms( 25 )
    end loop
    Jul 2005
    Hey, that's better then most programs do the first time thru!!!
    The code on page 6 doesn't have much to go wrong with it. 10 seconds sounds too long for something like the watchdog to fire, but I believe that will be on by default.
    What are you powering this with? Could the power be off after 10 secs?
    Sep 2006
    there is a 12v battery to the breadboard, and a LM7805 regulating the circuit at 5.0 volt. 4 Mhz oscillator with 22pf cap.s
    Like i says it does work fine with the *.jal program I found at http://www.voti.nl/blink/code/b818-2.jal
    but my program do not work for more then 10- to 20 seconds
    ken
    Sep 2006
    I have to add, if I unplug the power and wait like 5 minutes, then i get another series of 30 seconds blinking.
    If I just unhook the battery for a few seconds and put back the power, then it just barely flash and shut off.
    It seems some sort of memory is being unloaded and no power and filled up when it is activated.
    I has to do with the program , because it is working fine with the jal version
    k
    Jul 2005
    Interesting problem. Same code 2 different compilers, 2 diffrent results.
    Here's something to look at: Fire up MPLAB, select the device type to match your PIC, then import the hex code for each version in turn.
    See if there are any differences in the config bits.
  1. blinking problem with PIC16f887
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 26th January 2010, 02:04
  2. blinking LED
    By kindows in forum mel PIC BASIC Pro
    Last Post: - 31st July 2009, 16:08
  3. 7-segment display blinking problem?
    By serdar_ozcan in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 14:43
  4. Blinking LCD with using loop
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 5th August 2005, 13:24
  5. Button stops when i use Serin
    Last Post: - 8th July 2005, 14:35
