ADIS16250: Help with setting up SPI
Results 1 to 29 of 29
Threaded View
  1. #18
    Look fine but there's 2 mistake in this
         DEFINE HSER_CLOERR 1
    should be
         DEFINE HSER_CLROERR 1
    __________________________________________________
       INCLUDE "modedefs.bas"
    Nowhere in your code you're using MSBPRE, LSBPRE or else, you're using the SHIFTIN/SHIFTOUT mode # instead. You can remove this INCLUDE line.
    Just for safety sake, you should set CS0, CS1 to high before the main loop. Just before the PAUSE 1000
  1. Winbond ISD1700 Voice Recorder
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2014, 10:00
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  3. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 04:08
  4. 16-bit SPI problem
    Last Post: - 19th June 2008, 15:42
  5. How to configure SPI in PICBASIC PRO?
    Last Post: - 15th April 2007, 18:31
