Is it correct? Does it work?
Take a look on Table 41 STATUS Bit descriptions (Datasheet pp. 30):
Address 0x3D, 0x3C
Default 0x0000
Default is valid only until the first register write cycle.
Try reading X-Axis data or another register.
Address 0x3D, 0x3C
Default 0x0000
I tried reading the 0x04 register, and it just simply gives me 0x0000. I'm relatively sure my connections are right, but I could be wrong. Do I need any pull-ups? Are there any connections I need other than the SPI, reset, and power connections? Thanks
I have found that shiftin/out will not work with some devices,its the clock pulse timing I believe.Using the MSSI spi hardware port is an option,more involved though or write your own routine.Below is a sample I used with a Maxim 1270 A/D on a 16F877.
DataAcquisition:
for Indexer = 12 to 0 step -1 ' Output data,13 clock pulses
portc.2 = SerialDataOut.0[Indexer] ' Output data port
gosub Clockout ' Output clock pulse
next Indexer ' Next data bit,next clock pulse
for Indexer = 1 to 12 ' Read data,12 clock pulses
SerialDataIn = SerialDataIn * 2 ' Shift each bit to the left
SerialDataIn = SerialDataIn + portc.3 ' Data in port
return ' Complete return to main
Clockout: ' Clock pulse
pulsout portc.0,5 ' Clock pulse port, 1 msec
With shiftout, how can you use binary format instead of hex? Is there a method for translating binary into hex on the PIC?
Hello all, I finally got it working. I fixed it by changing the settings for the SHIFTOUT and SHIFTIN commands. Here is my source:
<code>
DEFINE OSC 20
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_SPBRG 21 ' 57600 Bauds
DEFINE HSER_CLOERR 1
DEFINE SHIFT_PAUSEUS 1000
INCLUDE "modedefs.bas"
Hserout ["ACTIVE",13]
RST var portd.0
SCLK var portd.1
CS var portd.2
DIN var portd.3 'data from PIC to Gyro
DOUT var portd.4 'data from gyro to PIC
temp1 var word
index var word
high RST
low CS
Shiftout DOUT, SCLK, 5, [$04\8,$00\8]
high cs
pause 10
low CS
SHIFTIN DIN, SCLK, 6, [temp1\16]
high cs
HSEROUT ["Temp1: 0x",dec temp1,13]
</code>
I wrote up some new code that is meant to use two ADIS16250 Gyros. Once I figure out what LSB (Not Least signifigant bit)(I think), I will use them in a RC Helicopter Navigation system.
<a href="http://initialdrivegtr.po.gs/SourceCode-2.htm">http://initialdrivegtr.po.gs/SourceCode-2.htm</a>
I hope this helps anyone that has had any trouble with these gyros too. Thanks for all your help!
InitialDriveGTR
