ADIS16250: Help with setting up SPI
Results 1 to 29 of 29
    How does one go about decreasing the SPI clock speed?
    Benjamin B. Roy
    Sep 2006
    Mexico
    Hello. add this line to your code:
    DEFINE SHIFT_PAUSEUS ms
    ms is the time in milliseconds between clock pulses
    What would be a good pause time? (Note that I am completely new to this)a
    Sep 2006
    Mexico
    To obtain clock speed:
    Freq [Hz] = 1/period[seconds]
    Test it with 1 ms (about 1Khz).
    If it doesnt work try with another SPI mode, remember MSB first.
    This is my code:
    <code>
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 21 ' 57600 Bauds
    DEFINE HSER_CLOERR 1
    DEFINE SHIFT_PAUSEUS 1000
    INCLUDE "modedefs.bas"
    Hserout ["ACTIVE",13]
    RST var portd.0
    SCLK var portd.1
    CS var portd.2
    DOUT var portd.3 'data from PIC to Gyro
    DIN var portd.4 'data from gyro to PIC
    temp var word'(2)
    index var word
    High SCLK
    High CS
    high RST
    low CS
    Shiftout DOUT, SCLK, 1, [$3C,$00]
    high cs
    low CS
    SHIFTIN DIN, SCLK, 2, [temp\16]
    high CS
    HSEROUT ["Temp: ",HEX4 temp,13]
    </code>
    And the output I am getting out is (HEX):
    ACTIVE
    Temp: 0000
    Temp: 0900
    Temp: 0900
    Temp: 0900
    Temp: 0900
    Sep 2006
    Mexico
    Is it correct? Does it work?
    Take a look on Table 41 STATUS Bit descriptions (Datasheet pp. 30):
    Address 0x3D, 0x3C
    Default 0x0000
    Default is valid only until the first register write cycle.
    Try reading X-Axis data or another register.
    I tried reading the 0x04 register, and it just simply gives me 0x0000. I'm relatively sure my connections are right, but I could be wrong. Do I need any pull-ups? Are there any connections I need other than the SPI, reset, and power connections? Thanks
  1. Winbond ISD1700 Voice Recorder
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2014, 11:00
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  3. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  4. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
  5. How to configure SPI in PICBASIC PRO?
