ADIS16250: Help with setting up SPI
Results 1 to 29 of 29
    Sep 2006
    Mexico
    Hello, the reset pin must be high or low, try adding RST=1 or RST=0
    Payatronico's Avatar
    Payatronico Guest
    Talking no no no
    muchacho amigo mio
    RST must be high, RST=1.
    maybe the problem is the crystal, try with a 4mhz cristal and more slowly speed of comunication, quiza asi se solucione tu problema chico
    Are the data adresses that I am shifting out correct? That is what I think I am doing wrong. I couldn't fully understand the datasheet's SPI output.
    InitialDriveGTR
    Sep 2006
    Mexico
    The data adresses is ok. However, the ADIS16250 SPI clock speed is 2.5 MHz, you need to decrease your clock speed in order to transfer data between devices.
    Try reading the status register of the ADIS16250 ($3C).
    How does one go about decreasing the SPI clock speed?
    Benjamin B. Roy
    Sep 2006
    Mexico
    Hello. add this line to your code:
    DEFINE SHIFT_PAUSEUS ms
    ms is the time in milliseconds between clock pulses
    What would be a good pause time? (Note that I am completely new to this)a
  1. Winbond ISD1700 Voice Recorder
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2014, 10:00
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  3. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 04:08
  4. 16-bit SPI problem
    Last Post: - 19th June 2008, 15:42
  5. How to configure SPI in PICBASIC PRO?
    Last Post: - 15th April 2007, 18:31
