Interrupts interfering with PRINT
Results 1 to 8 of 8
    Sep 2006
    Reading, UK
    Actually I am using Proton. I posted here automatically because I'm used to reading this forum. Would I be better off posting it elsewhere (at www.picbasic.org/forum)?
    Nontheless, here's a stripped down version of the full thing. (Which I compiled and tested to make sure it exhibits the same behaviour as the full version - it does!) Hopefully it's not too unintelligible. At the moment it's taking a value from a pot and placing it in pwmm1spd which the ISR uses to determine the duty cycle. When PORTB.7 is high it goes into a loop and spits some data out to the LCD.
    Thanks again. Any input is really appreciated.
    	Device 16F876A
    	Config HS_OSC, WDT_OFF, PWRTE_OFF
    	Xtal = 20
    	ON_INTERRUPT ipwm
    	' Assign some Interrupt associated aliases
    	SYMBOL T0IE = INTCON.5 		' TMR0 Overflow Interrupt Enable
    	SYMBOL T0IF = INTCON.2 		' TMR0 Overflow Interrupt Flag
    	SYMBOL GIE = INTCON.7		' Global Interrupt Enable
    	SYMBOL PS0 = OPTION_REG.0	' Prescaler ratio bit-0
    	SYMBOL PS1 = OPTION_REG.1	' Prescaler ratio bit-1
    	SYMBOL PS2 = OPTION_REG.2	' Prescaler ratio bit-2
    	SYMBOL PSA = OPTION_REG.3	' Prescaler Assignment (1=assigned to WDT 0=assigned to oscillator)
    	SYMBOL T0CS = OPTION_REG.5	' Timer0 Clock Source Select (0=Internal clock 1=External PORTA.4)
    	Declare	ADIN_RES		10	' Set number of bits in result
    	Declare	ADIN_TAD		FRC	' Set clock source (3=rc)
    	Declare	ADIN_STIME		10 	' Set sampling time in uS (was 50)
    	Declare LCD_TYPE		ALPHA
    	Declare LCD_DTPIN		PORTC.0
    	Declare LCD_ENPIN		PORTC.5
    	Declare LCD_RSPIN		PORTC.4
    	Declare LCD_INTERFACE	4
    	Declare LCD_LINES		2
    	symbol GLED				portb.5
    	symbol PWMCYLEN			60
    	symbol M1F				portb.4
    	symbol M1B				portb.6
    	symbol M2F				portb.2
    	symbol M2B				portc.7
    	dim i					as dword
    	dim j					as dword
    	dim	h					as dword
    	dim	k					as dword
    	dim asenscalib			as word
    	dim asensor				as dword
    	dim	potval   			as word
    	dim angle				as dword
    	dim oldangle   			as dword
    	dim	arate				as dword
    	dim speed   			as dword
    	dim oldspeed			as dword
    	dim	spdout				as byte
    	dim	torque				as dword
    	dim ptime				as word
    	dim	aCon				as word
    	dim	arCon  			as dword
    	dim pwmm1spd			as byte
    	dim pwmm2spd			as byte
    	dim pwmcycle			as word
    	dim incr				as dword
    	dim cpause				as byte
    	' PWM interrupt handler variables
    	dim intCount 		 as byte
    	dim direction		 as byte
    	GOTO overInterrupt
    	EDATA word 500, word 701, word 696, word 10, word 10
    	' Interrupt routine starts here
    ipwm:
    	asm
    	movfw 	pwmm1spd
    	subwf		intCount, w
    	btfsc		STATUS, C
    	goto		PWMOFF
    PWMON:
    	movlw   1
    	subwf	direction, w
    	btfsc	STATUS, Z
    	goto	FORWARD
    	bcf		M1B
    	bsf		M1F
    	bcf		M2F
    	bsf		M2B
    	goto		DONEPWM
    FORWARD:
    	bcf		M2B
    	bsf		M2F
    	bcf		M1F
    	bsf		M1B
    	goto		DONEPWM
    PWMOFF:
    	; Turn everything off
    	bcf	   	M1F		  	 ; Since this is the down part of the cycle
    	bcf		M1B			 ; Easier to turn everything off than test
    	bcf		M2F			 ; which motors to turn off...
    	bcf		M2B
    DONEPWM:
    	decfsz  intCount, 1			 ; Decrement intCount
    	goto 	intDoneStuff		 ; if NOT ZERO, then jump to intDoneStuff
    	movlw	255					 ; otherwise (if 0)... 255 into w
    	movwf	intCount			 ; reset counter
    intDoneStuff:
    	bcf	 T0IF 	   				 ; Clear the TMR0 overflow flag
    	endasm
    	CONTEXT RESTORE	' Restore the registers and exit the interrupt
    overInterrupt:
    	TRISB = %10000011
    	TRISC = $00
    	TRISA = $FF
    	ADCON1 = %10000001
    	M1F = 0	 		  ' Turn all motors off
    	M1B = 0
    	M2F = 0
    	M2B = 0
    	portb.2 = 0
    	delayms 25		  ' Wait for display (is this necessary?)
    	print $FE, 1, "     Hello"	' Clear display and show Hello
    	delayms 333
    	print $FE, 1  				' Clear display
    	pwmm1spd = 40
    	pwmm2spd = 40
    	intCount = 255
    	' Initiate the interrupt
    	GIE = 0 			' Turn off global interrupts
    	PSA = 1 			' Assign the prescaler to external oscillator
    	PS0 = 0 			' Set the prescaler
    	PS1 = 0 			' to increment TMR0
    	PS2 = 0 			' every 256th instruction cycle
    	T0CS = 0 			' Assign TMR0 clock to internal source
    	TMR0 = 0 			' Clear TMR0 initially
    	T0IE = 1 			' Enable TMR0 overflow interrupt
    	GIE = 1 			' Enable global interrupts
    	asenscalib = eread 0
    	ADIN 0, aCon
    	ADIN 2, arCon
    	aCon = aCon / 12
    	arCon = arCon * 35
    	oldspeed = 0
    	oldangle = 0
    	speed = 0
    	pwmcycle = 0
    	PORTB.5 = 0
    	incr = 1
    	i = 0
    	cpause = 0
    	delayms 10
    loop:
    	while PORTB.7 = 1					' Then we're in calibrate mode
    ''''''''''' test code
    		  ADIN 0, potval
    		  pwmm1spd = potval >> 2
    '		  M1F = 0	 		  ' Turn all motors off
    '		  M1B = 0
    '		  M2F = 0
    '		  M2B = 0
    		  speed = 0						' Reset values in case we've already been running...
    		  arate = 0
    		  oldangle = 0
    		  ADIN 1, asensor
    		  ADIN 0, aCon
    		  ADIN 2, arCon
    		  aCon = aCon / 12
    		  arCon = arCon * 35
    		  if arCon < 0 then
    		  	  print at 1, 1, "aK:", #aCon, " arK:-", #arCon, "(/10k)"
    		  	  print at 1, 1, "aK:", #aCon, " arK:", #arCon, "(/10k)"
    		  print 2, 1, "clb : ", #asensor, " (", #asenscalib, ")"
    		  if PORTB.1 = 1 then
    		  	 asenscalib = asensor
    			 ewrite 0, [asenscalib]
    	wend
    	' END OF CALIBRATION
    	' BALANCING ALGORITHM
    	direction = 1
    	ADIN 0, potval
    	goto loop
    In theory it's suppose to work, but i know i miss something in this one and with PROTON's HardWare/software Interrupt's stuff. I stay away of this compiler anyways since 'round 1 year.
    So i guess, the best way will be to use their forum to have the real answer for that.
    May 2006
    Del Rio, TX, USA
    I'm not up to speed on PROTON, but did see that the PRINT statements you use are not the same. The last one is missing the "AT" following the PRINT. I imagine this could cause some unexpected results.
    if arCon < 0 then
    Sep 2006
    Reading, UK
    Well spotted! Unfortunately putting it in doesn't seem to resolve the problem.
  1. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 23:39
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 07:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
