Problem with Bank 3 in 16F946
Results 1 to 3 of 3
    karlosguay's Avatar
    karlosguay Guest
    Exclamation Problem with Bank 3 in 16F946
    Sorry.
    1º. If i compile a program for 16F946, i have "Warning[219] c:\....\pbppic14.lib 892: Invalid RAM location specified"
    2º. In the file "16F946.bas" of PicBasic directory there is "BANK3 $0190, $01EF".
    3º. I read the datasheet of 16F946 and the start address of General Purpose Register in bank 3 is 1A0h and end address is 1EFh.
    There is a problem in the start address of "16F946.bas"????
    Best Regards, Karlos
    Hi karlosguay,
    That's good information! And it appears to be correct.
    You might want to drop a message to meLabs to let them know, since they never actually come around here to check things out.
    Could help out others in the future.
    [email protected]
    In the mean time, to fix the problem you're having, simply change the entry in
    your 16F946.BAS file from;
    BANK3 $0190, $01EF
    to;
    BANK3 $01A0, $01EF
    And you should be good to go.
    As Darell mentioned, I would inform MeLabs of the header file problem for this
    device.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  2. Replies: 14
    Last Post: - 26th September 2007, 05:41
  3. Microcontroller with 2 way paging application problem
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 05:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 17th February 2004, 23:44
