Pwm 16f876a
Results 1 to 9 of 9
Thread: Pwm 16f876a
    Jun 2005
    Wisconsin
    Default Pwm 16f876a
    I recently moved a project from a 16F88 to the 16F876A to gain more I/O. Previously the contrast of the LCD was controlled via PWM on CCP1, which worked perfectly. Since moving to the larger PIC I added PWM control of the backlight and can't get either to work.
    I have set everything up the same way and have all the defines correct. I have reread Melanie's post about backlight and contrast control. I have no clue where I'm going wrong. Help?
    ; -----[ Fuses ]----------------------------------------------------------
    @__config _HS_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
    ; -----[ Setup ]----------------------------------------------------------
    ADCON1=%10000110 ; Turn on A/D AN0 - Digital for the rest (16F876A specific)
    CMCON=%00000111 ; Disable Comparators
    TRISA=%11100001 ; PORTA Output/Input settings (1= Input 0=Output)
    TRISB=%00000001 ; PORTB Output/Input settings (1= Input 0=Output)
    TRISC=%10001000 ; PORTC Output/Input settings (1= Input 0=Output)
    OPTION_REG.6=1 ; INTEDG rising edge=1 falling edge=0
    T1CON.4=1
    T1CON.5=1
    ; -----[ Defines ]----------------------------------------------------------
    DEFINE OSC 20 ; 20 mhz XTAL (change notes above)
    DEFINE I2C_SLOW 1
    DEFINE HSER_BAUD 9600 ; 9600 Baud USART
    DEFINE HSER_RCSTA 90h ; Enable USART RX
    DEFINE HSER_TXSTA 24h ; Enable USART TX
    DEFINE HSER_SPBRG 51 ; 9600 Bauds
    DEFINE HSER_CLROERR 1 ; Clear all USART errors as they happen
    DEFINE LCD_DREG PORTB ; LCD 20x2
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE CCP1_REG PORTC ; HPWM 1 pin port
    DEFINE CCP1_BIT 2 ; HPWM 1 pin bit
    DEFINE CCP2_REG PORTC ; HPWM 2 pin port
    DEFINE CCP2_BIT 1 ; HPWM 2 pin bit
    what happen if you remove
    Since this PIC don't have alternate pin for any CCPx, i don't know how it's handled.
    And the obvious, if i can... did you really selected the right PIC in the editor?
    Also, you should have a space between @ and __Config. But it could be a forum copy/paste problem so..
    Also, even if not PWM related
    You have two definition of the Baudrate... one is false. Or you keep HSER_BAUD 9600 or you correct the HSER_SPBRG 51 to HSER_SPBRG 129. 51 is the right value for 8MHZ.
    Jun 2005
    Wisconsin
    If I remove the defines I get the same results, which is nothing.
    And yes, 16F876A for CodeDesigner Lite & ICProg.
    mmm how about the frequency? @20MHZ the minimum should be 'round 1.2KHZ if you're using HPWM.
    Jun 2005
    Wisconsin
    Here are the subs I'm using.
    ; -----[ LCD Contrast PWM ]-----------------------------------------
    PWM_Contrast:
    value=Contrast*40
    HPwm 1,value,1000
    ; -----[ LCD Backlight PWM ]----------------------------------------
    PWM_BackLight:
    value=Backlight*51
    HPwm 2,value,1000
    As i said, the minimum frequency should be 1.2Khz. 1.3KHZ work fine here. So change it to...
    PWM_Contrast:
    value=Contrast*40
    HPwm 1,value,1300
    PWM_BackLight:
    value=Backlight*51
    HPwm 2,value,1300
    About now?
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. 16f876a Pwm
    By Hainkm in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 18:33
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
