Pwm 16f876a
Results 1 to 9 of 9
Thread: Pwm 16f876a
    Jun 2005
    Wisconsin
    Here are the subs I'm using.
    ; -----[ LCD Contrast PWM ]-----------------------------------------
    PWM_Contrast:
    value=Contrast*40
    HPwm 1,value,1000
    ; -----[ LCD Backlight PWM ]----------------------------------------
    PWM_BackLight:
    value=Backlight*51
    HPwm 2,value,1000
    As i said, the minimum frequency should be 1.2Khz. 1.3KHZ work fine here. So change it to...
    PWM_Contrast:
    value=Contrast*40
    HPwm 1,value,1300
    PWM_BackLight:
    value=Backlight*51
    HPwm 2,value,1300
    About now?
    Jun 2005
    Wisconsin
    Of course, you are correct changing to 1300 worked. Which, now that I think about it, makes sense because I was using the internal 8mHz clock on the 16F88.
    Thanks for the help, its my first time with PWM. Needless to say I will remember this in the future.
    I may ask Melanie to make a note about this in here FAQ.
    So my guess in the previous post #2 about SPBRG value was correct. You should modify it NOW!
    And... the minimum frequency range is stated in the PBP manual... OUPS!
    Glad to know it's working now.
    Have fun!
    Jun 2005
    Wisconsin
    I did the RTFM thing and saw the chart. I just didn't make the link mentally between the chart and my code. I will in the future.
    Thanks!
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. 16f876a Pwm
    By Hainkm in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 18:33
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
