Multiplexing PWM pin with other outputs
Results 1 to 3 of 3
    Feb 2003
    Sydney, Australia
    Default Multiplexing PWM pin with other outputs
    Hi All,
    Just running through a concept here. I have a button plate with LED feedback for each button.
    I want to use the PWM output used to create a 'backlight' that will illuminate all the status leds at a lower level when the button feedback outputs are not high. The Backlight is driven from the PWM out from the 16f87 (via a transistor to produce the required drive for the 4 LEDS).
    First thought was to use a couple of diodes (poss schottkys to reduce the V drop) to act as an old school OR gate to drive the LEDs:
    (Cheesy ASCii art follows..)
    <code>
    PWM---[>|-----[>|--[___]---+5
    ...........| (LED) 560R
    LED---[>|--
    </code>
    Any comments before I proto it and see if I blow anything up ??
    Bill.
    Feb 2003
    Change the "+5" to "0V" or it wont work at all
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Feb 2003
    Sydney, Australia
    Arr, mmm, yes
    that was a test. well done.
    8-)
  1. 12F683 2 x PWM Outputs
    Last Post: - 23rd July 2021, 20:20
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. pwm to pin using variable
    By wsmrite in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 17:08
